Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. HI folks,
    Iam trying to merge an audio in audio file for particular seconds using ffmpeg......Can you pl send me command line ......
    Thanks in advance
    Vijay123.....
    Video streaming?
    I'm moving you to our audio section. No, I have no idea to do it just with ffmpeg. Maybe easier with sox.
  3. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    The obsession with command line stuff is mind-boggling.
  4. Hi hech4
    i will you clear you my question again ,just merging an audio into an audio file, is it possible to do using FFMPEG.?...........If it so means send me the command..................
