I have 3 mini dvs all recorded one after another. Tapes 1 & 3 are fine. On tape 2, only one-third of the screen shows. The left two-thirds of the screen is black, when played through a deck. When the tape is played through the original camera (Cannon GL2) the video still plays in the right third of the screen, but the two thirds on the left now has a still image of the first frame shot.
I'd be surprised if this is a clogged head issue, seeing how the mini tape used immediately after this was fine. I'm assuming it's just a bad tape. Does anyone have any leads to a way to extract a clean video off the tape?
Results 1 to 1 of 1
Using Sp/LP mini DV in a Sony Mini DV Player
By Gsmurfet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 21st May 2013, 21:38 -
3 chip non-hd mini-dv playback issues
By durfer in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 2nd Aug 2012, 23:20 -
How to Cut & Merge mini 10 part mini series?
By skorpinok in forum EditingReplies: 5Last Post: 8th Oct 2011, 09:41 -
Capture progressive mini-dv tape on interlaced mini-dv cam ?
By alip in forum Capturing and VCRReplies: 4Last Post: 8th Feb 2011, 17:27 -
Hardware choices: standalone mini-DV deck, or cheap mini-dv camera?
By SgtRauksauff in forum Newbie / General discussionsReplies: 3Last Post: 14th Oct 2008, 02:18
