I know the answer is around here somewhere, can't seem to find it on site, so here goes....Have the TMPGEnc, did a capture with MMC 7.6 at MPEG2 (480x480) even tried the MMC Reg Tool to set up a standard SVCD template. Capture is not a problem. Now the problem is trying to open in TMPGEnc (any version) Have all the Plug-Ins, VFPI's, MPEG2 Codec, looked at the Priority setting the the options, when I open I get the following
Not Support, Can't Open File
Running WIN98 in one system and WIN2000 Pro in the other, same results. So what am I missing?
You need a frameserver
DVD2AVI is the best for this job.
You can find it on the links section.
Also, look at the guides: How to convert mpeg 2 to XXXXX -
I can open them fine in the latest bersion of Tmpgenc.
My priorities for the vfapi plugins are as follows:
Directshow is 4
AVI VFW is 3
Mpeg2 Video plugin is 3 listed below AVI VFW
AVI2 is 0
Let me know if this helps. I just installed 7.6 for my AIW 128 Fury pro. Seems ok, but vid looks a bit blurry to me. Got to keep playing with it. -
Found out my problem was a VBRun type file that was not loaded, found the file downloaded it, after I loaded that everything works great with the SVCD ....
Bud
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
TMPGEnc to License x264 Encoder for TMPGEnc 4.0 XPress
By poisondeathray in forum Latest Video NewsReplies: 17Last Post: 28th Jan 2011, 15:07 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
