I had an unexpected problem after demuxing a large flv file (1.15 GB) with FLVExtract and unfortunately, only noticed it after making too much job with it - as the extractor hadn't shown any error message. It appeared like everything above 1GB had been ignored at demuxing (both audio and video). Is it a known issue (or maybe even flv type limitation)? I'm almost sure my original file is OK. In that case I had to separately use a smaller cut for getting the end of the video. Is there a similar software for extraction, handling larger files? Thank you in advance.
Have you tried flvextract 2.1 also ? https://code.google.com/p/flv-extraxct/
Or try ffmpeg, see http://www.simonbrenner.org/Special_Blog?id=11 for some examples. -
small side note: afaik ffmpeg can't extract the timecodes, so you might still need to use FLVExtract to extract the time codes if the input is vfr.
How to join four .flv files in to one .flv file using ffmpeg?
By spiderMan007 in forum EditingReplies: 3Last Post: 26th Aug 2012, 14:18 -
Compress large FLV file to a smaller size FLV file
By RustyBob in forum Video ConversionReplies: 1Last Post: 26th Oct 2011, 18:21 -
Problem with demuxing .ts file
By iXed in forum DVB / IPTVReplies: 5Last Post: 8th Aug 2010, 10:14 -
Demuxing a TS file
By carlmart in forum Video ConversionReplies: 17Last Post: 29th Jul 2009, 16:04 -
Multiple FLV files into 1 big FLV file, how??
By vividbreeze in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2008, 16:11
