Hi Folks-
Any advice about the best Free program to accept my VOB(I can convert if I have to) video and use a filter to remove
some audio distortion? Would love not to have to export the audio file and re-join afterwards if at all possible.
Thanks Much,
Steve F.
Thanks for the replies.
You can hear the audio it's just at the very top end of the voices there is a bit of "mechanical" sounding distortion like it's turned up to high. I thought perhaps running it through an Audacity noise reduction filter might help but, knowing my lack of intuition in these matters, tried to avoid the inevitable head scratching that would come from trying to export the audio and rejoin it after processing. Is any particular program more "idiot friendly" than another for this? -
Something wrong with Audacity?
The rejoining and putting back into the DVD is easy. First you gotta fix the audio, if possible. A short sample might help.
http://terrywest.nl/utils.html
Distortion in audio
By carlmart in forum AudioReplies: 2Last Post: 3rd May 2011, 14:59 -
Audio distortion
By silveringking in forum AudioReplies: 0Last Post: 26th Jan 2011, 17:13 -
Video out of synth after connecting audio and video(after removing dubbing)
By marnisper in forum Newbie / General discussionsReplies: 11Last Post: 20th Dec 2009, 04:09 -
Removing blur / distortion using Virtualdubmod
By denadel in forum EditingReplies: 5Last Post: 14th Jul 2009, 20:09 -
Removing audio and adding it to new video...help
By dandad1 in forum AudioReplies: 1Last Post: 2nd Dec 2008, 02:34
