I’m looking for a program that will auto backup files to azip drive. Yes I know there are plenty out there. Problem is the programs wantto “zip”, reconfigure, house the files in folders or encrypt the files. I justwant it to back up the files and when I look at the files that were transferredto the zip they are unaltered and no other files reside on the flash drive.Maybe someone has an idea.
Don't give in to DVD2ONE, that leads to the dark side.
I've been using Syncback from http://www.2brightsparks.com/ to backup my documents to a network connected drive every night. When I go to the backup drive it looks just like the original drive. Folders, subfolders, and files intact, no compression. You get to define the destination drive and folder so I don't see any reason why it wouldn't work to a zip drive. I don't think it backs up open files so make sure all your documents are closed at backup time. So far, I've been happy with it. They also have two other versions SyncbackSE and SyncbackPro, but I've been satisfied with the basic version.
Buy My Books -
Thanks, I'll give it a shot.
Don't give in to DVD2ONE, that leads to the dark side. -
Simple and it works. Thanks G
Happy to help. Glad it fit your needs.
Buy My Books
Any external SATA 3.5 enclosures with auto-shutdown
By jntaylor63 in forum ComputerReplies: 2Last Post: 15th Jun 2011, 19:32 -
Epiphan VGA2USB external device for sale!
By vexed_xx in forum Capturing and VCRReplies: 1Last Post: 19th Jul 2010, 10:05 -
External Hard Drive that Auto Sleeps...Any?
By ron spencer in forum ComputerReplies: 2Last Post: 10th Mar 2010, 13:24 -
Recommend one good external capture device
By jranaudo in forum Capturing and VCRReplies: 1Last Post: 8th Jan 2010, 02:35 -
External analogue capture device to stream to Livestream/uStream etc
By batfastad in forum Video Streaming DownloadingReplies: 0Last Post: 22nd Jul 2009, 06:59
