Hello everyone,
I am trying to convert videos of gameplay that I've recorded with MSI Afterburner to get a better file size and compression. I tried using MeGUI, but I'm having issues - the video speeds up at some point after the begining causing it to desync with the audio. Also the speed up is pretty obvious - even if the audio is off you can notice it clearly. Also it syncs back in at the end of the video. I'm using the one click interface of megui, only changed the bitrate for smaller file size and the container to mp4.
Here is some info from Mediainfo about the files recorded with MSI Afterburner:
I would appreciate any help on the matter since I'm pretty green with anything related to video editing. Thank you for your time.Code:General CompleteName : C:\Users\pzf\Videos\z-Screen Recording\ForConvert\Vindictus_2013_06_22_16_59_00_842.avi Format : AVI Format/Info : Audio Video Interleave FileSize/String : 997 MiB Duration/String : 4mn 34s OverallBitRate/String : 30.5 Mbps Video ID/String : 0 Format : JPEG CodecID : MJPG Duration/String : 4mn 34s BitRate/String : 29.0 Mbps Width/String : 1 280 pixels Height/String : 768 pixels DisplayAspectRatio/String : 1.667 FrameRate/String : 24.000 fps ColorSpace : YUV ChromaSubsampling : 4:2:0 BitDepth/String : 8 bits Compression_Mode/String : Lossy Bits-(Pixel*Frame) : 1.227 StreamSize/String : 946 MiB (95%) Audio ID/String : 1 Format : PCM Format_Settings_Endianness : Little Format_Settings_Sign : Signed CodecID : 1 Duration/String : 4mn 33s BitRate_Mode/String : Constant BitRate/String : 1 536 Kbps Channel(s)/String : 2 channels SamplingRate/String : 48.0 KHz BitDepth/String : 16 bits StreamSize/String : 50.0 MiB (5%) Alignment/String : Aligned on interleaves Interleave_Duration/String : 42 ms (1.00 video frame)
Edit: now that I've checked again, it slows down at some points, at other it is sped up.
Edit2: I have noticed that the framerate changes after the conversion, I guess this is the problem. But how can I set this up in MeGUI?
I did convert everything I had so far, I will try this when I record something again. Thank you.
Not getting stereo audio with MSI afterburner video captures
By brassplyer in forum Newbie / General discussionsReplies: 0Last Post: 16th Apr 2013, 13:24 -
Problems with framedropping in VirtualVCR + Audiosync in MSI TV @nywhere Pl
By Anonymous1 in forum Capturing and VCRReplies: 2Last Post: 21st Nov 2012, 10:36 -
Editing Afterburner h264 AVIs? what program?
By TheFounderX in forum EditingReplies: 6Last Post: 20th Aug 2012, 20:46 -
Problems playing recorded .mp4 files
By dhr3 in forum Software PlayingReplies: 2Last Post: 8th May 2011, 13:17 -
Absolute confusion - advice for editing/converting files recorded in MCE 7
By elsmandino in forum Video ConversionReplies: 3Last Post: 11th Nov 2010, 17:24
