This is a PAL DVD. I've tried the solution which jagabo suggest me days earlier, but it works not very perfect on this one.
Code:LoadPlugin("D:\Program Files\Megui\tools\avisynth_plugin\yadifmod.dll") LoadPlugin("D:\Program Files\Megui\tools\avisynth_plugin\nnedi2.dll") yadifmod(mode=1, order=1, edeint=nnedi2(field=3)) Import("D:\Program Files\Megui\tools\avisynth_plugin\SRestore.avs") SRestore()
http://files.videohelp.com/u/221292/boom.demuxed.rar
It's a progressive PAL video with out-of-phase fields. Each frame contains half of one film frame, half of the next. You can fix that with:
orCode:TFM()
The former is usually a better method since it will adapt to changes in the pattern. Ie, the video may alternate between in-phase and out-of-phase sections.Code:SeparateFields().Trim(1,0).Weave()
Interlacing problem
By xuguang_he in forum RestorationReplies: 30Last Post: 21st Apr 2013, 01:18 -
Interlacing problem?
By killerteengohan in forum DVD RippingReplies: 16Last Post: 18th Aug 2011, 07:24 -
VHS to Pc with Videograbber & de-interlacing
By MERLiN4U in forum Newbie / General discussionsReplies: 0Last Post: 1st Mar 2011, 13:25 -
De-interlacing & Encoding problems.
By rossfcp in forum MacReplies: 1Last Post: 29th Aug 2009, 22:32 -
Good Video Explaining Interlacing and De-Interlacing
By Soopafresh in forum Newbie / General discussionsReplies: 3Last Post: 14th Aug 2008, 20:50
