Hi, I'm editing a .MPG video (MPEG-1, 640x480) in Sony Vegas, to upload it to YouTube afterwards.
How can I render it best in Vegas, so YouTube's flash converter won't f it up too much?
thanks
Can't you just upload the MPG file? Seems like the fewest conversions route would get the best quality.
use mainconcept avc, some internet export, use custom preset, or Sony avc while exporting, you might use some memorystick export, set avc and customize it . Or maybe there is youtube exports under those categories, not sure now.
highest bitrate you can afford (more bitrate -> longer upload), but beware that you cross certain bitrate where increasing it more makes little sense, that threshold should be around 6,000 kbps for average VBR 2pass or CBR 1pass depends of what is in your video, how noisy it is etc.
As for CBR you might cut quality during bitrate demanding scenes and waste bitrate at the same time while there is bitrate not needed to be that high for some scenes.
SD will not look good on youtube anyway to keep nowadays standards, resolution is just too low.
Is this the highest possible quality for YouTube? YouTube compresses video?
By chrissyelle in forum Newbie / General discussionsReplies: 17Last Post: 5th Oct 2010, 11:33 -
Uploading a video to Youtube that will fill the ENTIRE youtube player.
By Clifurd in forum Video ConversionReplies: 16Last Post: 12th Mar 2010, 13:40 -
Youtube HD 1080p settings? Youtube conversion out of sync!
By DoubleJMan in forum Video ConversionReplies: 12Last Post: 5th Jan 2010, 01:04 -
Why won't YouTube convert a video that was downloaded from YouTube?
By brassplyer in forum Video Streaming DownloadingReplies: 0Last Post: 5th Dec 2008, 04:47 -
MPG for Youtube?
By Evhmoon in forum DVD RippingReplies: 10Last Post: 10th Aug 2008, 15:03
