My son has a lot of movies that I am trying to backup to a hard drive. Mostly because he likes to play with the actual dvd's and he tends to dirty them up and scratch them. I have repetedly tried to back up theses DVD's using both DVD Decrypter (this is what i used to use back in the day flawlessly) and DVDFab. Once I rip the DVD i use VidCoder or Handbrake to convert the DVD file to an MP4, but this another story completely. I have noticed that my problems don't stem from converting but are all from the ripping. The DVD's stop and an error message pops up that says there was a problem ripping the dvd. This is not with all the DVD's but the majority of them...I have only been able to rip about 20% of his DVD's. Any help/suggestions would greatly be appreciated...
Error im getting in Decrypter...
Error im getting in DVDFab...
Results 1 to 13 of 13
Try cleaning the disc. Is it scratched? It is possible the disc is damaged and you will have to use recovery software
Thanks i will try to clean the dvd's and retry. Like i said he likes to handle them a lot so they are fairly scratched and dirty. Although I don't believe this is the complete problem. Recovery Software?
There is 'recovery' software that claims to read from scratched disks. Here is a link to one
http://www.makeuseof.com/tag/fix-unreadable-cds-or-dvds-in-windows/
I am one of the more sceptical types and, having never used this (never needed to) I do find such claims rather incredulous. At best I would have thought the software just skips over a bad sector whereas the the software you use just stops when it fails to read.
I would also ask if you can play these disks in any player as it could just be your PC drive that is causing the failures. -
[QUOTE=DB83;2249249]There is 'recovery' software that claims to read from scratched disks. Here is a link to one
</quote>
I tried the Roadkill software...it is the same as the DVD Decrypter and DVDFab...it seems to always be getting stuck on one .VOB file. -
well ive tried all the above suggestions and still am having trouble ripping my discs.
Try an older drive or another machine. I keep an ancient (2X) panasonic in an external enclosure for difficult to read discs. If it can't read the disc (sometimes after cleaning with a Disc Dr.), it's too far gone.
;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
im sorry i still haven't tried going to another machine...i will try this next...
For the I/O ERROR, Try going into Device Manager, Then Go to IDE ATA/ATAPI controllers, Right click on your ATA Channel then click on properties then click on advanced settings then look under where it says current mode, If it has Ultra DMA with a number your OK! If it has IPO, Then click cancel, Then right click on your ATA Channel again and click on uninstall, Reboot your system and windows should pickup your hardware and install it correctly, This is what worked for me.
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 04:50 -
Help in DVD Ripping?
By itsjamesd in forum MacReplies: 6Last Post: 9th Nov 2010, 13:55 -
Ripping Saw 6 (Saw VI) dvd, HELP!!!
By diluvian8 in forum DVD RippingReplies: 5Last Post: 27th Jan 2010, 22:45 -
DVD Ripping help
By nsx-r in forum DVD RippingReplies: 3Last Post: 30th Apr 2009, 19:56 -
Ripping from DVD
By SamohAD in forum DVD RippingReplies: 2Last Post: 23rd Mar 2009, 04:34
