Page 2 of 2
FirstFirst 1 2
Results 31 to 39 of 39
  1. DECEASED
    Jun 2009
    Heaven
    Then right-click on the EXE, and choose "Run in XP-compatibilty mode" or something
    ( only now I notice you have the GRRRREEEAT and picky Windows 7 ).
    Also, do not forget to run it as ADMINistrator.
    Jun 2013
    North America
    XP Compatibility worked. (Windows XP gives that security pop-up too!) Also, when I extract the audio I get a weird matroska file (.mka). No idea how to use that. What am I doing wrong?
    Edit: Windows 7's Read about this file type function has no idea what a mka file is
  3. DECEASED
    Jun 2009
    Heaven
    From the PDF:
    3.1.6 Extracting Streams
    You can right-click on an audio or subtitle streams. If AVI-Mux GUI supports extraction of
    that stream to a separate file, the corresponding menu item will show up.
    From the infamous "rtfm.txt":
    Your mouse has a right button, so please use it!
    Many features, like demuxing audio, setting AAC-sources to be HE-AAC,
    setting default flags, are available through the right mouse button.
    H.T.H.
    P.S.: But now that you already have an MKA, you could also try this:
    ffmpeg -i input.mka -acodec copy output.mp2
    Jun 2013
    North America
    That MP2 file was a test, I need to merge the video clips together before I do it for real. Besides, no idea where I would type that code. Anyway, I reght clicked and extracted stream, and it extracted as .mp3, not .mp2. Is that right? Also, sometimes, maybe when it's done processing or when I click something, the name of the video file in the top box turns red. The first time I made an MKA, It got an error, which I wasn't able to read since I happened to be pressing spacebar when it popped up. I tried to replicate it again, but the second time there was no error with making an mka file.
    Jun 2013
    North America
    I think I've got everything sorted out now:
    1. Record audio and video
    2. Crop, merge, and encode video clips with XViD default configuration
    3. Extract audio form above with AVImux GUI
    4. Edit microphone audio in Audacity
    5. Merge audio tracks in Audacity [WAIT A MINUTE] how do I do that?
    6. Put audio track back on video, using direct streamc copy
    7. Upload to YouTube
    How do you put multiple audio tracks into one file in Audacity? I know very little about Audacity...
    Jun 2013
    North America
    OK, I think I've figured out how to do everything. I'll post back if I have any more problems. Thanks for the help El Heggunte!
    Jun 2013
    North America
    Looks like I had a problem after all. In adition to normalize, export and pretty much every other menu option is grayed out. I tried selecting both (ctrl+a) and clicking on each track individually. They are different lengths if it matters. You should know the formats from MediaInfo.
    What's grayed out:
    Almost entire file menu
    Entire effect menu
    Most of Transport
    All of Generate
    All of analyze
    none of help
    A bit of view
    About half of the rest
  8. DECEASED
    Jun 2009
    Heaven
    As I said before, me too knows nothing about Audacity , the only GUI-based editors I have are Wavosaur and Goldwave.
    Anyway, if the tracks don't have the same length, you must add some silence to the short one (either at the beginning or at the end), so that you keep everything "in synch". Then you can mix and normalize.
    Jun 2013
    North America
    Oh, you know nothing about Audacity? Oh well
    I guess I need to make a new topic for that. Also, the lengths shouldn't have to be the same b/c I saw a tutorial where someone put a short song before their voice for a podcast.
    Thx for all your help though!
