Hi all, I need to buy an active 3D monitor to watch the stream from 2 cameras with my application (it shows 2 streams in side by side format). As far as I could see, with a passive polarized monitor all I need to do is to switch to full screen mode and activate the 3D side by side monitor option. Is it the same with an active monitor like the BenQ xl2420tx?
I have a nVidia Quadro 4000 with DVI output.
If the BenQ xl2420tx shouldn't match the specifications, could you please suggest me another suitable monitor?
Thank you.
it might work if you use the nvidia video player. no way to know if your videos are compatible with it.
BENQ DW1670 issues
By kyrcy in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th Jan 2010, 17:00 -
Looks like my benq 1620 may be dying, any writers burn 8x @ 12x?
By Denvers Dawgs in forum DVD & Blu-ray WritersReplies: 10Last Post: 27th Jul 2009, 12:05 -
Benq 1620 tray will not open? Just makes a click sound.
By Denvers Dawgs in forum ComputerReplies: 5Last Post: 23rd Jul 2009, 00:12 -
Benq EW162I DL burner Problem
By wanghiking in forum Authoring (DVD)Replies: 9Last Post: 20th Nov 2008, 19:09 -
Which Benq DVD burner is the best
By Habby in forum DVD & Blu-ray WritersReplies: 1Last Post: 12th Oct 2008, 12:43
