I can't afford to drop $300 to $500 on a new Canon camcorder. Do you have any suggestions on a model or two that might be a couple years old that is perfectly serviceable? I'm looking for an HD camera takes SD Cards and is average to good in low light situations.
That's like asking what used Chevy that has a V8 engine is best. You probably won't get many good answers to your question but I sure would look at Ebay for starters.
What I have noticed is that Best Buy clearances some of the older models for half off what they sell for on Amazon and they also sell out of box items that were displays in the store. I did buy my last Canon camcorder on eBay, but I do feel like I would be rolling the dice on eBay. The other thing I've seen is that Canon sells refurbished models for less than retail as well.
Well there you go. Try Best Buy. Problem with that is, you will have to visit the store every week or so to finally find what you are looking for. Also try Canon for refurbished models.
Here's what I found at Best Buy in terms of open box cameras:
HF R30, HF R300, HF R40, HF R42, HF R400, HF M50.
The best price I have seen is the HF M50 Open Box for $169.99 (It's on clearance at most Best Buys for $299). Based on numbers that's the most expensive models of the ones above.
Canon XH-A1 Camcorder Recommendation?
By digital10 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 30th Jun 2011, 20:18 -
I need help with Canon Vixia HF R10 HD Camcorder
By Nugrl in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 22nd Dec 2010, 15:40 -
PC does not see Camcorder Canon Legria FS200
By [KoR]Double in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 2nd Dec 2009, 09:55 -
Those with the Canon HG10 HD Hard drive camcorder...
By matt3756 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 9th Dec 2008, 16:30 -
Editing 16:9 movies from Canon FS10 camcorder.
By alpinestar in forum EditingReplies: 6Last Post: 17th Sep 2008, 03:14
