Hello,
I'm a student and for my project I have to work with data that come from video tracking. I'm using a software (Tracker) to do this but I have a big problem with the frame rate and the spatial resolution.
My video is 1920i/60 and when I open it with Tracker, it uses the Xuggle engine to read the video with bad results. So I need to deinterlace the video before open it with Tracker.
So my problem is:
is possible to deinterlace my video keeping that frame rate (60) and also the resolution?
Thank you for your help
Saluti
	There is no such thing as a perfect deinterlacer and there never will be. It's impossible to perfectly recreate the original two full pictures from two half pictures. But AviSynth's QTGMC() is currently the best (and very good). Second best is probably Yadif(mode=1), also AviSynth. Yadif is also available in VirtualDub. All of those will give you 60p.
 A sample of your video would be helpful. The best deinterlacing algorithm sometimes varies depending on the nature of the source.Last edited by jagabo; 18th Jun 2013 at 08:46.
	Thanks for your answer,
 I'm not an expert in programming so I'll try to see how AviSynth works. Cause VirtualDub doesn't read the MOV file, can I use Avisynth to open the file in VirtualDub? and then deinterlace it? or something like that!?
 The thing that I don't understand is: what are the steps that I have to do to get the point?
 thank you again!!
	VirtualDub can read MOV files with the MP4 or DirectShow source plugins.
 Yes (see below).
 Yes. Though if you're going to open the file in AviSynth you might as well deinterlace it there.
 From scratch you have a long way to go....
 Install AviSynth. Download QTMGC.AVSI and put it in AviSynth's plugins folder.
 http://avisynth.org/mediawiki/QTGMC
 Download all the other plugins required by QTGMC and put them in AviSynth's plugins folder. Create an AviSynth script (a plaint text file with .AVS as the extension) that reads something like:
 Or:Code:DirectShowSource("filename.mov") AssumeTFF() # or Assume BFF(), whichever is appropriate for your source QTGMC()
 The latter will required you download and install the ffmpeg source plugin for AviSynth.Code:ffVideoSource("filename.mov") AssumeTFF() # or Assume BFF(), whichever is appropriate for your source QTGMC()
 Finally, you open the AVS file with VirtualDub as if it was a video file: File -> Open Video File.
  Should I Interlace this VideoBy bob52 in forum Video ConversionReplies: 6Last Post: 30th Oct 2012, 19:50
  interlace helpBy nymph4444 in forum Newbie / General discussionsReplies: 339Last Post: 17th Jun 2011, 03:33
  Interlace or Bitrate ??By garylanders in forum Authoring (DVD)Replies: 1Last Post: 29th Dec 2010, 14:43
  Question about HD to SD and interlace>progressive>interlaceBy ayim in forum Video ConversionReplies: 4Last Post: 10th Dec 2009, 13:21
  Just get rid of interlace problems, no good quality expectedBy TheOtherSwede in forum Video ConversionReplies: 8Last Post: 13th May 2009, 15:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
