The process aborts on this and one other compilation. No clue why or how to fix it. Ive been using AVStoDVD for a while and never had issues till now.
<6/17/2013 4:51:21 AM>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: NTSC
DVD Titles number: 4
DVD Size: 4450/4450 MB (100%)
DVD Output Setup: DVD Folder
DVD Label: Game of Thrones S3 E1-4
DVD Menu: Static Menu
Output Folder: D:\TV Shows\GameofThrones S3\1-4
Delete Temp Assets Files: Yes
Delete Temp Working Files: Yes
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
MultiThread: 1
AVS Video Source Filter: A2DSource
AVS Audio Source Filter: A2DSource
AVS UpSize/DownSize Filter: Lanczos4Resize/Spline16Resize
Frame Adjust Strategy: 1
PAL SpeedUp: 0
Video Resolution: 0
Video BitRate Min: 2500
Video BitRate Level 1: 6500
Video Profile Level 2: 4500
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
Force FFmpeg for Long Audio: 1
DVD Audio Format: 0
DVD Audio BitRate: 192
Keep DVD Compliant Audio: 1
Normalize Audio: 0
Auto Delay Audio: 1
DVD Audio Language (Primary): EN - English
DVD Audio Language (Secondary): EN - English
DVD Subs Language (Primary): EN - English
DVD Subs Language (Secondary): EN - English
DVD Subs Font: Tahoma 18pt (255,255,255)
Chapters Interval: 5
Use Source Chapters: 1
DVD Burning Drive: E: ATAPI DVD A DH16A3L 8H1B
DVD Burning Speed: 4x
Auto Erase DVD RW: 1
Unload ActiveMovie library: 0
Adjust ffdshow at runtime: 1
Save General Settings: 0
TITLE 1 SOURCE FILES
Video: D:\Complete\Season 3\Game.of.Thrones.S03E01.HDTV.x264-2HD.mp4
Info: AVC - 862 kbps - 720x402 - DAR 1.791 - 23.976 fps (CFR) - Progressive - 54:29 minutes - 78383 frames
Audio 1: D:\Complete\Season 3\Game.of.Thrones.S03E01.HDTV.x264-2HD.mp4
Info: AAC LC - 123 kbps - VBR - 2 ch - 48000 Hz - 54:29 minutes (0 ms delay)
[MediaInfoLib - v0.7.61]
AVISYNTH SCRIPT
Import("D:\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("D:\Complete\Season 3\Game.of.Thrones.S03E01.HDTV.x264-2HD.mp4", CacheFolder="C:\Users\Kavic\AppData\Local\Temp", FrameRate=23.976, VFR=false)
Audio = A2DAudioSource("D:\Complete\Season 3\Game.of.Thrones.S03E01.HDTV.x264-2HD.mp4", CacheFolder="C:\Users\Kavic\AppData\Local\Temp")
Video = Video.ConvertToYV12()
Video = Video.Lanczos4Resize(720,480)
#Using DGPulldown/HCenc to upsize FPS
AudioDub(Video, Audio)
START VIDEO ENCODING OPERATIONS
Encoding Profile: HCenc VBR 2-pass
Target Video FileSize: 977.7 MB
Encoding Parameters: -ini "C:\Users\Kavic\AppData\Local\Temp\Game of Thrones S3 E1-4_3_Title_01_Game.of.Thrones.S03E01.HDTV.x264-2HD.HCenc.ini"
HCenc ini file:
*INFILE C:\Users\Kavic\AppData\Local\Temp\Game of Thrones S3 E1-4_3_Title_01_Game.of.Thrones.S03E01.HDTV.x264-2HD_1.avs
*AVSRELOAD
*OUTFILE C:\Users\Kavic\Videos\Game of Thrones S3 E1-4_3_Title_01_Game.of.Thrones.S03E01.HDTV.x264-2HD.m2v
*LOGFILE C:\Users\Kavic\AppData\Local\Temp\Game of Thrones S3 E1-4_3_Title_01_Game.of.Thrones.S03E01.HDTV.x264-2HD.HCenc.log
*MAXBITRATE 9000
*BITRATE 2509
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*PULLDOWN
*BIAS 30
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY NORMAL
*DBPATH C:\Users\Kavic\AppData\Local\Temp
*WAIT 2
<6/17/2013 6:09:17 AM>
END VIDEO ENCODING OPERATIONS
Created File: C:\Users\Kavic\Videos\Game of Thrones S3 E1-4_3_Title_01_Game.of.Thrones.S03E01.HDTV.x264-2HD.m2v (978.8 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 2511 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 54:29 minutes - 78394 frames
START AUDIO ENCODING OPERATIONS (Track 1)
Wavi+Aften Parameters: "C:\Users\Kavic\AppData\Local\Temp\Game of Thrones S3 E1-4_3_Title_01_Game.of.Thrones.S03E01.HDTV.x264-2HD_1.avs" - | "D:\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\Kavic\Videos\Game of Thrones S3 E1-4_3_Title_01_Game.of.Thrones.S03E01.HDTV.x264-2HD_1.ac3"
<6/17/2013 6:12:21 AM>
START FFMPEG (SAFE MODE) AUDIO ENCODING OPERATIONS (Track 1)
FFmpeg Parameters: -threads 2 -i "D:\Complete\Season 3\Game.of.Thrones.S03E01.HDTV.x264-2HD.mp4" -map 0:1 -y -vn -acodec ac3 -ar 48000 -ab 192k "C:\Users\Kavic\Videos\Game of Thrones S3 E1-4_3_Title_01_Game.of.Thrones.S03E01.HDTV.x264-2HD_1.ac3"
<6/17/2013 6:13:03 AM>
END AUDIO ENCODING OPERATIONS (Track 1)
Audio Source Filter: A2DSource (DirectShowSource)
Created File: C:\Users\Kavic\Videos\Game of Thrones S3 E1-4_3_Title_01_Game.of.Thrones.S03E01.HDTV.x264-2HD_1.ac3 (74.8 MB)
OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 16 bit - 54:29 minutes (0 ms delay)
TITLE 2 SOURCE FILES
Video: D:\Complete\Season 3\game.of.thrones.s03e02.hdtv.x2640-2hd.mp4
Info: AVC - 1039 kbps - 720x404 - DAR 1.782 - 23.976 fps (CFR) - Progressive - 57:05 minutes - 82121 frames
Audio 1: D:\Complete\Season 3\game.of.thrones.s03e02.hdtv.x2640-2hd.mp4
Info: AAC LC - 127 kbps - VBR - 2 ch - 48000 Hz - 57:05 minutes (0 ms delay)
AVISYNTH SCRIPT
Video = A2DVideoSource("D:\Complete\Season 3\game.of.thrones.s03e02.hdtv.x2640-2hd.mp4", CacheFolder="C:\Users\Kavic\AppData\Local\Temp", FrameRate=23.976, VFR=false)
Audio = A2DAudioSource("D:\Complete\Season 3\game.of.thrones.s03e02.hdtv.x2640-2hd.mp4", CacheFolder="C:\Users\Kavic\AppData\Local\Temp")
Target Video FileSize: 1024.4 MB
Encoding Parameters: -ini "C:\Users\Kavic\AppData\Local\Temp\Game of Thrones S3 E1-4_3_Title_02_game.of.thrones.s03e02.hdtv.x2640-2hd.HCenc.ini"
HCenc ini file:
*INFILE C:\Users\Kavic\AppData\Local\Temp\Game of Thrones S3 E1-4_3_Title_02_game.of.thrones.s03e02.hdtv.x2640-2hd_1.avs
*AVSRELOAD
*OUTFILE C:\Users\Kavic\Videos\Game of Thrones S3 E1-4_3_Title_02_game.of.thrones.s03e02.hdtv.x2640-2hd.m2v
*LOGFILE C:\Users\Kavic\AppData\Local\Temp\Game of Thrones S3 E1-4_3_Title_02_game.of.thrones.s03e02.hdtv.x2640-2hd.HCenc.log
*MAXBITRATE 9000
*BITRATE 2509
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*PULLDOWN
*BIAS 30
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY NORMAL
*WAIT 2
<6/17/2013 7:10:36 AM>
Created File: C:\Users\Kavic\Videos\Game of Thrones S3 E1-4_3_Title_02_game.of.thrones.s03e02.hdtv.x2640-2hd.m2v (324 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 2554 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 17:43 minutes - 25504 frames
Wavi+Aften Parameters: "C:\Users\Kavic\AppData\Local\Temp\Game of Thrones S3 E1-4_3_Title_02_game.of.thrones.s03e02.hdtv.x2640-2hd_1.avs" - | "D:\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\Kavic\Videos\Game of Thrones S3 E1-4_3_Title_02_game.of.thrones.s03e02.hdtv.x2640-2hd_1.ac3"
<6/17/2013 7:12:46 AM>
FFmpeg Parameters: -threads 2 -i "D:\Complete\Season 3\game.of.thrones.s03e02.hdtv.x2640-2hd.mp4" -map 0:1 -y -vn -acodec ac3 -ar 48000 -ab 192k "C:\Users\Kavic\Videos\Game of Thrones S3 E1-4_3_Title_02_game.of.thrones.s03e02.hdtv.x2640-2hd_1.ac3"
<6/17/2013 7:13:18 AM>
Created File: C:\Users\Kavic\Videos\Game of Thrones S3 E1-4_3_Title_02_game.of.thrones.s03e02.hdtv.x2640-2hd_1.ac3 (78.4 MB)
OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 16 bit - 57:05 minutes (0 ms delay)
TITLE 3 SOURCE FILES
Video: D:\Complete\Season 3\Game.of.Thrones.S03E03.HDTV.x264-EVOLVE.mp4
Info: AVC - 902 kbps - 720x404 - DAR 1.782 - 23.976 fps (CFR) - Progressive - 54:16 minutes - 78082 frames
Audio 1: D:\Complete\Season 3\Game.of.Thrones.S03E03.HDTV.x264-EVOLVE.mp4
Info: AAC LC - 115 kbps - VBR - 2 ch - 48000 Hz - 53:44 minutes (83 ms delay)
AVISYNTH SCRIPT
Video = A2DVideoSource("D:\Complete\Season 3\Game.of.Thrones.S03E03.HDTV.x264-EVOLVE.mp4", CacheFolder="C:\Users\Kavic\AppData\Local\Temp", FrameRate=23.976, VFR=false)
Audio = A2DAudioSource("D:\Complete\Season 3\Game.of.Thrones.S03E03.HDTV.x264-EVOLVE.mp4", CacheFolder="C:\Users\Kavic\AppData\Local\Temp")
Audio = Audio.DelayAudio(0.083)
Target Video FileSize: 974.2 MB
Encoding Parameters: -ini "C:\Users\Kavic\AppData\Local\Temp\Game of Thrones S3 E1-4_3_Title_03_Game.of.Thrones.S03E03.HDTV.x264-EVOLVE.HCenc.ini"
HCenc ini file:
*INFILE C:\Users\Kavic\AppData\Local\Temp\Game of Thrones S3 E1-4_3_Title_03_Game.of.Thrones.S03E03.HDTV.x264-EVOLVE_1.avs
*AVSRELOAD
*OUTFILE C:\Users\Kavic\Videos\Game of Thrones S3 E1-4_3_Title_03_Game.of.Thrones.S03E03.HDTV.x264-EVOLVE.m2v
*LOGFILE C:\Users\Kavic\AppData\Local\Temp\Game of Thrones S3 E1-4_3_Title_03_Game.of.Thrones.S03E03.HDTV.x264-EVOLVE.HCenc.log
*MAXBITRATE 9000
*BITRATE 2509
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*PULLDOWN
*BIAS 30
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY NORMAL
*WAIT 2
<6/17/2013 3:51:41 PM>
Process aborted during Title 3 VIDEO encoding operations.
For Video issues troubleshooting see Help/FAQ/Video section.
Log file created by AVStoDVD Release 2.7.0
Thats nice, not helpful but nice. Could I get a real response please, and leave the BS at the door. Thank You
Proccess aborted during DVD Authoring operations!
By coffecat in forum Authoring (DVD)Replies: 7Last Post: 20th Jan 2013, 11:08 -
"Process aborted during DVD AUTHORING operations!"
By Jockie in forum Authoring (DVD)Replies: 2Last Post: 8th Dec 2012, 17:45 -
AVStoDVD MP4 problem Process Aborted during subs encoding operations
By stem300 in forum Authoring (DVD)Replies: 7Last Post: 22nd Nov 2012, 12:38 -
AVStoDVD mkv problem Process Aborted during subs encoding operations
By stem300 in forum Authoring (DVD)Replies: 1Last Post: 12th Jun 2012, 17:08 -
AVStoDVD 2.3.2 - Process aborted during DVD Burning Operations
By Mark97213 in forum Authoring (DVD)Replies: 5Last Post: 25th Oct 2010, 14:05
