Results 1 to 15 of 15
    Jan 2007
    Hi,
    I want to record from my netgear neotv max which is hooked up to my roxio game capture hd pro. Since it doesn't work because i guess signal protected-hdcp, will a hdmi switch or spltter allow for the signal to pass so i get a unprotected signal to my roxio device. Here are two i am looking at right now.
    Hdmi switch-MIS-SWHK0401
    http://www.centralcomputers.com/commerce/catalog/product.jsp?product_id=83028&czuid=1371509519468
    hdmi splitter-lu604m
    http://www.centralcomputers.com/commerce/catalog/product.jsp?product_id=81836&czuid=1371506031953
    By the way when a hdmi splitter has hdcp passthrough, does that mean it strips hdcp protection or not or will signal pass through unprotected?
    Also, if i just use an hdmi coupler to join hdmi cables, you think that would work for what i am trying to do? Thanks for all great replies.
    oh yeah, if any of those don't work, can anybody from these short lists-determine if it all which will work for my situation?
    search for hdmi splitter and hdmi switch
    looking for the lowest priced one
    Thanks again!
  2. Originally Posted by Milardo View Post
    A switch is a dumb device. It just routes wires from an input to an output. The receiving device and the sending device negotiate HDCP.
    A splitter negotiates HDCP with the source, then negotiates HDCP with each output device. It is not supposed to "strip" HDCP. That said, there are some non-compliant HDMI splitters that do strip HDCP -- ie they don't apply HDCP to the outputs. But you have to search for them. There's a big thread here about HDCP strippers.
    https://forum.videohelp.com/threads/334145-HDCP-strippers
    I don't know about the particular devices you linked to. But if you find devices that look identical (aside from the silk screening) to those that are confirmed to strip HDCP you will be more likely to get what you want.
    Jan 2007
    Can you search at that same site and see if any of those match for hdmi splitter?
    http://www.centralcomputers.com/commerce/catalog/product.jsp?product_id=73226&czuid=1371506031953
    this one looks similar to the ones from that thread, but i'm not sure
  4. This is one of the confirmed HDMI strippers:
    www.amazon.com/CVID-BG-550-portable-Powered-Splitter/dp/B0089DVCT8/
    The one in your link doesn't look exactly like that.
    Jan 2007
    Do any of the products from this company work for what i am trying to do?
    http://www.east-toptech.com/Products.html###
  6. The HDMI to composite converters will only give you standard definition output.
    Jan 2007
    Actually i meant their splitters-hdmi
  8. The page you linked to had only a cable and 2 HDMI/composite converters. I didn't see anything on their HDMI switch/splitter page that looked exactly like the 1x4 splitter (or its 1x2 sibling) at Amazon.
    Jan 2007
    If a product has hdcp passthrough , would that bypass hdcp protection? Also what would a hdmi repeater do?
  10. Originally Posted by Milardo View Post
    No.
    It will not remove HDCP, just boost signal levels.
    Jan 2007
    So I'm thinking of buying the one here
    http://www.amazon.com/CVID-BG-550-portable-Powered-Splitter/dp/B0089DVCT8/
    Does audio get passed through as well?
  12. Originally Posted by Milardo View Post
    Yes. I have that model and have verified it removes HDCP.
    Jan 2007
    Oh actually i meant does audio get transferred as well as video to whatever device be it a tv or anything that has hdmi input?
  14. If audio is in the HDMI signal it gets passed through along with the video.
    Jan 2007
    Got the splitter a couple of days ago, tested today with the hardware i have, and it works!
