Hi,
I have two problems concerning interlaced mp4 video.
Problem 1:
Is there a chance to convert interlaced mpeg2 video to mp4 interlaced output (no de-interlacing at all)? I didn't find this option in Handbrake, the output is always progressive. Should I use other software?
Problem 2:
I have some mp4 files, that are interlaced, but my TV and my PC think, they are progressive (strong comb-effects). Is it possible to change the wrong file headers?
Thanks for your help!
Miepel
PS: Please excuse my poor English.
1) make sure Handbrake doesn't screw up the interlacing with incorrect filtering. Then:
https://forum.videohelp.com/threads/344902-Detelecine-decomb-issues?p=2151515&viewfull=1#post2151515 -
I think your problem 2 gives the answer to your problem 1. Many (Most? All?) players won't deinterlace x264 video encoded as interlaced. Either deinterlace it or bob it before/while encoding.
Edit: After reading jagabo's reply and link, it's not 'All' players won't deinterlace it. Maybe just 'Many'? -
Most players I've used will detinterlace h.264 if it is encoded and flagged as interlaced. I think he meant the frames are interlaced but they were encoded (and flagged) as progressive. I don't know if there are any tools that would let you change the flag. In any case, it wouldn't really work right -- the chroma channels will be screwed up.
i hv seen many H264/AVC1 videos screwed up with incorrect filtering and containing improper de-interlacing artifacts while scene change.screw up the interlacing with incorrect filtering.
Can an interlaced file appear not to be interlaced on the monitor?
By rcavanah in forum Authoring (DVD)Replies: 5Last Post: 10th Sep 2011, 22:09 -
Interlaced.... or not?
By pgoelz in forum Capturing and VCRReplies: 29Last Post: 15th May 2011, 22:20 -
Interlaced or not
By edong in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 26th Oct 2010, 09:17 -
Interlaced but not
By tb582 in forum Newbie / General discussionsReplies: 3Last Post: 24th Aug 2010, 14:08 -
Converting DV to H.264 and comparing interlaced/de-interlaced
By amirh1 in forum Video ConversionReplies: 5Last Post: 23rd Jun 2010, 09:16
