I'm capturing some VHS tapes which I capture at 720x480. I've been taking small segments of the files and creating DVD test files to compare different restoration solutions, which I watch on my WS TV. I've noticed that my test files play back on my Sony BluRay player at 720x480 (natch!) but when I play the VHS tapes from the VCR, the display fills the wide screen. I assume it has something to do with the way my TV processes the signal from the VCR, but perhaps someone more knowledgeable than me could explain why it happens that the VCR display is wide screen but the DVD playback remains 720x480 when the source is the same. Thanks.![]()
Your DVD player is reading the headers and playing back in 4:3 as it should. Your TV is stretching the output from the VCR to fill the screen. It may be as simple as pressing the 'Wide' button on your TV remote, some will default to full screen unless told otherwise.
I doubt that's true. 720/480=1.5 and, assuming you reencoded them for DVD as 4:3, they're playing in some 1.33:1 ratio, something more like 640x480.
I have no idea why your tapes when played through the VCR fill the screen, but it's most likely what Richard_G said - something set up wrong somewhere. My tapes play as they should (1.33:1 with pillarbars added to the sides) when played on my widescreen TV set. -
I bet your BluRay player is connected to your TV using HDMI, which forces your TV to use the correct aspect ratio.
I bet your VHS machine is connected to your TV using composite, which allows you to set the incorrect aspect ratio (which you have done).
Even in Europe, where composite via SCART carries one or even two signals to tell the TV the correct aspect ratio, TVs still allow users to over ride this and set the incorrect aspect ratio if they really want to. You can sometimes do this with an HDMI input too - it depends on the TV, and the exact signal sent over HDMI. Some devices upscale SD video to HD, adding black bars either side, before sending the picture to the TV - in this case, there's no way any TV will ever display it stretched to fill the screen.
Cheers,
David. -
convert 50p and 59.94p 264 to 1080 25i and 1080 29.97i
By wiseant in forum Video ConversionReplies: 8Last Post: 13th Aug 2012, 16:02 -
1080 60i to 1080 50i
By spikespiegel17 in forum Video ConversionReplies: 13Last Post: 15th Jun 2012, 10:08 -
LCD display failed on Sony 1080
By MJW01 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 15th Nov 2011, 06:23 -
Signal System : 1080/50p , 1080/50i on HDC-SD700
By wisitch in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 22nd Sep 2010, 08:11 -
1080/29.97psf with 2:2:2:4 cadence back to 1080/23.98p, how?
By metalvic20 in forum Video ConversionReplies: 0Last Post: 17th Dec 2008, 13:28
