I recently used VFAPI conv to load PAL DV files into CCE 2.5, worked fine. I tried the same with CCE 2.64, OK too. But seddenly it all stopped working> I reloaded a Ghost image of my OS & applications and started again, loading CCE, TMPGEnc. Still does not work.
CCE comes up with an error message "unable to open ....tpr_VFAPI.avi, file not found". I'm using VBR 3 pass (Win XP, Athlon 1200).
I would like it to work again as I use the deinterlace filter in TMPG for some clips. The DV avi's I can load straight into CCE (I installed the Mainconcept DV codec), but I need to deinterlace some clips.
Can I use the AVI2SVCD function in DVD2SVCD?? Will it accept DV avi's?
Any ideas on why I can't get VFAPIconv to work again.
