Hi Everyone,
I've been using a pretty nifty HTPC setup for a while lately, hooked into my Yamaha HTR-6130 using a coax cable however will only give me 2ch Pro-Logic.
The HTPC that I bought (using an MSI-7411 Media Live DIVA with 7ch Pre-Amp card) has analogue surround outputs, so I figured I would give those a burl.
Bought some good RCA cables, hooked them into the Multi-CH input on my Yamaha, and hey presto -- absolutely nothing.
I am convinced it's a driver issue, because the Realtek software that drives the audio chipset can detect that I'm not using SPDIF anymore, but doesn't seem to notice that I have a mass of cables plugged into the pre-amp card.
Anyone have any ideas on what I could have done wrong here? Am about ready to start pulling hair out...>
Results 1 to 1 of 1
zoom h4n vs pre amp for microphone
By gtxrla in forum AudioReplies: 16Last Post: 28th Feb 2013, 09:40 -
Panasonic DVD & USB & SD Card Slot Problem
By Tim Sage in forum DVD & Blu-ray RecordersReplies: 1Last Post: 20th Mar 2011, 18:23 -
Title Playback Pre & Post Commands, back to menu, select next button
By louv68 in forum Authoring (DVD)Replies: 4Last Post: 19th Feb 2009, 19:24 -
Need to get a stronger signal - use an antenna pre-amp?
By Mr. Burn in forum DVB / IPTVReplies: 13Last Post: 24th Jan 2009, 16:56 -
Help installing xp on HP dv9910 laptop w/vista pre-installed & sata hd
By freebird73717 in forum ComputerReplies: 5Last Post: 14th Sep 2008, 19:54
