Try StreamFab Downloader and download streaming video from Youtube, Netflix, Amazon! Download free trial.
Page 2 of 3
FirstFirst 1 2 3 LastLast
Results 31 to 60 of 61
  1. Originally Posted by jagabo View Post
    Freemake doesn't work here. It shows all the different videos but none of them will download. I just get an error message after a bit: "Error: no downloadable video available at this URL"
    Right. I went back to make another picture like ChristianoA did, but showing it had been successfully downloaded. Now I get the same as you. They must have changed something right after I got it. Even the sizes are no longer the same. I've uploaded it here:
    http://www.mediafire.com/?6cuq892m2pdcf0u
  2. DECEASED
    Jun 2009
    Heaven
    Over here, both Savetube and Savevideo return the following error message:
    The remote server refuses to perform the request. This address is not available.
    Jul 2010
    Akron, Ohio
    Thanks a lot for the share; I really appreciate it.
    And no, MassTube does not work in this instance. I must point out that it has a really sneaky installer. I got by without installing any "suggested" extras, but non-intuitive types won't have any idea what they're doing in that regard.
    Jul 2010
    Akron, Ohio
    File identified as FLV, but this is actually the WEBM version. Just a minor setback, thanks again for the share.
    Actually I lied. Unfortunately, it's a major setback.
  5. Originally Posted by CyberTootie View Post
    Why's that? It reencodes easily enough, doesn't it? Or is there some other reason it's not suitable?
    Jul 2010
    Akron, Ohio
    Player plays it fine, but project I'm doing right now involves Premiere, it won't read it, tried DirectShow filters, my encoder of choice is mishandling colors decoding VP8, don't have any more time to dedicate to this one inclusion, I just phased it out.
  7. Know any AviSynth? There might be more efficient ways to do it but this works to open the video and audio:
    A=FFVideoSource("Stone Temple Pilots - Sex Type Thing (Official Video).flv")
    B=FFAudioSource("Stone Temple Pilots - Sex Type Thing (Official Video).flv")
    AudioDub(A,B)
    Open that in VDub and save out the audio as WAV audio. Save out the video as something lossless (Lagarith or the like). Then you'll have something for Premiere. You'll need to have the FFMS2.dll:
    http://code.google.com/p/ffmpegsource/
    Jul 2010
    Akron, Ohio
    Alright, thanks, I may have time to give that a shot.
    Jul 2010
    Akron, Ohio
    Hmm, I put the dll in the Avisynth plugin directory, yes? I'm getting "No function named FFVideoSource".
  10. Originally Posted by CyberTootie View Post
    One would think just putting it in the plugins directory would be enough. I always use a loadplugin line in my scripts. I just tested by removing the line and got the same message as you did. So, somewhere near the top of the script try adding:
    LoadPlugin("C:\Path\To\ffms2.dll")#adjust for your path
    I hope that's enough to get you going.
  11. Originally Posted by manono View Post
    Odd. I just have ffms2.dll in the plugins folder. No explicit LoadPlugin.
  12. Oh good, you showed up. What else does he have to do? I also have an ffmsindex.exe I put in with my dlls. I removed it and it still indexed his music video. Is it or anything else necessary, do you know, to get FFMPEGSource working? I don't use FFMPEGSource all that much myself and don't know all its ins and outs.
  13. DECEASED
    Jun 2009
    Heaven
    My AVSplugins\FFMS2 folder contains FFMS.avsi, FFMS2.dll and ffmsindex.exe.
    Besides,
    REGEDIT4
    [HKEY_LOCAL_MACHINE\SOFTWARE\Avisynth]
    "plugindir2_5"="C:\\Path-To\\AVISYNTH\\plugins"
    however my "default" Avisynth plugins folder contains only DirectShowSource.dll and 3 other files,
    because I don't like to complicate things
    ( not when dealing with Avisynth's setup at least )
    Jul 2010
    Akron, Ohio
    It's in. Thank you so much.
  15. DECEASED
    Jun 2009
    Heaven
    Just for the notes --- the videos by VEVO are NOT being cached in the same way as before
    ( not with Opera 11.64 at least --- the cached files are being split into many parts ).
    "Ordinary" YouTube videos do not have this problem
    ( so far, at least ).
  16. Try Youtube Video and Audio Downloader, https://addons.mozilla.org/en-US/firefox/addon/youtube-video-and-audio-dow/. The new version works just fine
  17. Originally Posted by joeertaba View Post
    Thanks, joeertaba. It works here, too.
  18. Member
    Jul 2013
    Canada
    Lately, I'm finding that when I attempt to play videos downloaded from YouTube using RealPlayer Downloader, I'll get a Cannot Render The File, along with an error message. This only seems to occur with recently uploaded videos. Does anyone know if this is some sort of new copy protection that YouTube has recently adopted?
    On a side note, for some reason, whenever I reinstall RealPlayer (I've also recently found that just having certain videos in my RP Folder will cause my CPU to max out and freeze up just by trying to access it!) , the RealPlayer Downloads file goes into my shared folder instead of the default My Videos, which is where I want it. I'm the only user of My Computer, so administrative permissions SHOULDN'T be an issue, here!
    Any feedback would be greatly appreciated!
  19. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    4K Downloader
  20. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    i can't believe anyone voluntarily uses real player. thought they died out long ago, looks like unfortunately not. get something like vlc or mpc-hc.
    Jul 2013
    Canada
    I only really use Realplayer to download videos via their Realplayer Downloader. I'm beginning to suspect part of my problem has partly to do with the updated Realplayer itself.
    Another problem I've been encountering over the past 10 months or so is that nearly every time I download an online program (Or even uninstalling/reinstalling Realplayer!), some stupid rogue search engine attaches itself, and I have to go through all of the B.S. that goes with ridding oneself of such things! This is not just a once in awhile issue, I could deal with that! And yes, I have done the Virus/Infection checks to try and fix this, to NO AVAIL! Does anyone know if there is a way of fixing this, or is this simply an inevitable part of the price of being online these days?
  22. Member MysticE's Avatar
    Nov 2003
    I think it's safe to say there are major problems with YouTube in general. On another forum folks were accusing their ISP's of throttling their access to it.
    Sometimes vids work fine, sometimes they stall.
    You probably noticed you can no longer pause the vid and let it load.
    FWIW I opted into to this:
    http://www.youtube.com/html5
  23. Hi,
    I can't download the following videos in 1080p:
    http://www.youtube.com/watch?v=Tff2oE31Mlw
    http://www.youtube.com/watch?v=lmgEoh_r_XM
    Can you please help me?
    Klaus
  24. no idea?
  25. Originally Posted by flashandpan007 View Post
    Hi,
    In addition, Internet Download Manager can get the videos.
  26. Triple-Monitor Gamer iHaz3Monitors's Avatar
    Oct 2013
    Madison, WI
    Ants that understand bacon eat. Cakes and those cookies have everyone running.
  27. DECEASED
    Jun 2009
    Heaven
    Until proven otherwise, you are a sock-puppet of enim,
    https://forum.videohelp.com/members/222198-enim
  28. Triple-Monitor Gamer iHaz3Monitors's Avatar
    Oct 2013
    Madison, WI
    I don't know, is this some sort of inside joke?
