    Jun 2013
    Malaysia
    I am using handbrakeCLI to convert video.. whatever setting I used, it shows
    High@L3.1..
    how can I get High@L4.1??????
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    L3.1 is a subset of L4.1, so that shouldn't matter. Everything capable of decoding L4.1 should also be able to handle L3.1.
    Not sure if it does, but... if handbrakeCLI automatically sets the lowest valid level within the set of features and encoding options used for a particular video, then I would think that is an awesome feature.
  3. Member ozok's Avatar
    Oct 2011
    Turkey
    Please use a better topic title. Current one says nothing about your question and question marks are annoying.
    Jun 2013
    Malaysia
    owh.. I see.. thanks Case
    Im sorry ozok, I will write better next time
