Hello,
I am a newbie and complete idiot when it comes to making VCD's and have a question about Nero burning Rom. I am tryng to download it from Morpheus but not sure what file to download.
Should I download the one which says --
cracked.zip?
Also, how do I know what file is best to download? Do I look for the size of bitrate? Is the higher bitrate better for mpeg files?
I am on a quest to make my first VCD - please help!
Nina
I would get a non-cracked version to start with, then if you want to do said deed then get a suitable keygen from morpheus after.
Of course cracking is illegal, but you already knew that, right? -
Just go to www.nero.com and purchase the software. It's only $49.00 for the serial number. I could give you a serial number, but it is only good for Yamaha recorders, oh yea, I also have one that is only good for Creative Lab recorders. Or you could do like me and purchase a good serial number from NERO. I tried the hacked serial numbers and spent more time trying to get one to work than I did on creating my VCDs. Not worth the time. BE LEGAL Buy it.
Ypu have to ask yourself the question: is it worth spending 50 odd pounds or dollars on someting that you could get for free, in the form of cd-mate, clone cd, cdrwin,vcdeasy etc??
just go download the demo at aheads home page then go to www.astalavista.box.sk .. and you can take it from there..
go to www.nero.com d/l the latest version and private msg me for the serial number ok or try astalavista.box.sk for a cravk but dout there will be 1 for nero 5.5.8.0 or watever the newest version is just msg me and ill help u with it
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Nero Burning Rom 8.3.6.0
By jebinio in forum ComputerReplies: 1Last Post: 14th Sep 2008, 10:29 -
NERO burning help
By efiste2 in forum Authoring (DVD)Replies: 6Last Post: 11th Jan 2008, 08:35 -
how to create folders in nero burning rom or express?
By jyeh74 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Dec 2007, 23:54 -
DVD-ROM to DVD Burner Direct Burning
By Wilson7777 in forum DVD RippingReplies: 6Last Post: 15th Jun 2007, 11:37
