me buy two sports coaching dvd from germany. one is very good. other one when i play in dvd player, coach instructions is low volume, and when they display demonstration with background music. music is very high volume. me can not adjust coach instructions and background music with remote to same volume. me can not find guide. possible to repair audio inside dvd easy way?
this dvd has only video_ts folder. when you play you can select 3 different language but all has same volume problem.
General
Complete name : D:\VIDEO_TS\VTS_01_1.VOB
Format : MPEG-PS
File size : 1 023 MiB
Duration : 16mn 19s
Overall bit rate : 8 764 Kbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=12
Duration : 16mn 19s
Bit rate : 8 000 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 4:3
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.772
Time code of first frame : 09:59:59:15
Time code source : Group of pictures header
Stream size : 935 MiB (91%)
Audio #1
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Duration : 16mn 19s
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Delay relative to video : -80ms
Stream size : 22.4 MiB (2%)
Audio #2
Format : MPEG Audio
Duration : 16mn 19s
Bit rate : 192 Kbps
Audio #3
Format : MPEG Audio
Duration : 16mn 19s
Bit rate : 192 Kbps
Menu -
Your audio is 2 channel MPEG-1 layer 2 audio. You won't be able to fix the problem. If you had 5.1 audio it might be possible to fix the problem, depending on what was in the 6 audio channels.
I'm guessing that this DVD is old because as far as I know nobody in Europe has used MPEG-1 layer 2 audio in DVDs in years. Does it have subtitles? I don't see a reference above to subtitles, but if it has subtitles maybe you can read those.
I'm puzzled by your use of "me" where you should be saying "I". You have posts in the past where you use "I" correctly. Recently around here you're acting like Tarzan in your posts (you won't understand that reference, but others will). OK, I understand that English is probably not your native language, but if you're acting dumb deliberately to try to get help, that's not necessary. -
today my dvd shop guy told audio defect in dvd. me trying replacement exchange from supplier.
Espero que este foro deben estar en espanol. gracias.
Dvd to .avi audio problem
By gartzo in forum Video ConversionReplies: 5Last Post: 21st Feb 2012, 09:04 -
.mkv to DVD-5 converting problem with audio
By akakiami in forum Video ConversionReplies: 5Last Post: 19th Apr 2011, 10:11 -
DVD audio problem
By ra300z in forum DVD RippingReplies: 4Last Post: 7th Jun 2009, 11:21 -
Burning DVD audio problem
By Jragon16 in forum Newbie / General discussionsReplies: 4Last Post: 7th May 2009, 22:20 -
DVD / VOB audio delay problem
By TrashCompaqtor in forum AudioReplies: 9Last Post: 22nd Jan 2009, 04:56
