Hi there I am wondering if there is a newer and better program than abcavi. I want to remove some tags present in some of the videos I've downloaded because the names appear different when streaming to the xbox using the system video player... So yeah is there a newer or better program than abcavi that works?
(Abcavi wouldn't work for me for some reason)
Results 1 to 11 of 11
Avi Demux and Virtual Dub are not the same types of programs lol... I need a program that is better than abcavi... (abcavi allows editing of avi metadata eg. comment)
If you're on Windows Seven or Vista, at least try to run the program under the XP-compatibility mode. If even this suggestion doesn't work, then just forget Abcavi + ffmpeg + VirtualDub, and learn to hex-edit your problematic AVI files
ExifTool GUI for Windows might be worth a try,.. iirc it should work for avi files too
TigoTago (http://tigotago.com) might also be worth, checking out (I have never used it) -
FYI this version is quite outdated and the latest version can be found here:
http://u88.n24.queensu.ca/~bogdan/
ExifTool executable needs to be renamed, read carefully the "Requirements and preparations".
Although I have no idea if it's working with AVI files as I haven't tried yet
Okay I got the program setup with the Gui and I clicked on the video that I want to change the metadata of. How do I actually change the metadata? I tried clicking "exifTool direct" but it tells me to enter in a command line which of curse I do not know... I have also tried double clicking on the metadata I want to change and this does nothing... Any ideas?
Need Better Program than AbcAVi to edit video file tags
By Whitezombie455 in forum Newbie / General discussionsReplies: 5Last Post: 6th Feb 2013, 02:17 -
Updating to newer components for an out-of-date Program (Multiavchd)
By Moontrash in forum Authoring (Blu-ray)Replies: 2Last Post: 20th Jan 2012, 16:12 -
Good program for ripping DVDs with newer protection?
By Crossdive in forum MacReplies: 3Last Post: 30th May 2011, 00:51 -
Trying to get an OLD program to run on a "newer" pc....
By Noahtuck in forum ComputerReplies: 13Last Post: 8th Aug 2009, 09:38 -
abcAVI Tag Editor: Add, Browse and Change AVI tags
By devilcoelhodog in forum Newbie / General discussionsReplies: 0Last Post: 1st Mar 2009, 07:37
