Results 1 to 14 of 14
  1. I was wonder, what would be the best software(s) for 3D particle effects? For example, something like in the picture I attached below.
    I know I would need to 3D track the scene, but what would I use to actually make that effect of falling particles?
Name:	3D Particle Example.jpg
  2. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Use a particle simulator.
  3. Originally Posted by budwzr View Post
    Yes, but can you list some?
  4. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    The one I use is in HitFilm.
  5. Originally Posted by budwzr View Post
    Thank, is there any tutorials on how to do 3D Particles with HitFilm?
  6. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Yeah, check the website.
    "Blender" is a free one. But it's tough to learn. The UI is non-normal.
  7. Originally Posted by budwzr View Post
    Thanks, you have been a big help!
    Feb 2004
    Australia
    If you recreate the scene as shown then blender is one program ... with video it may, thou that feature is relatively new
    Some guides on particle simulation
    May 2013
    Turkey
    Blender 2.5+ UI is good than Maya, 3dsmax, Softimage and other programs. Old Blender version UI bad, but new UI is pretty good.
    TheJDKProductions, if you know any 3D program, then use it. If don't know, then this work is hard for you, because you must firstly learn use 3D program and 3D methodologies.
    If you don't want spend thounds dollars, then use Blender.
  10. As an alternative to the software plugins, there are several products based on the ready-to-use overlays with particles. Particulas is one of them - for creating floating dust effects.
    Here's the demo video:
    And best of all - 5 FREE video particle effects
    Jun 2008
    A well-known paid software is trapcode particular. It has a free trial.
    Also, adobe after effects has some particle effects and you can make it better by writing expressions.
  12. Member Cornucopia's Avatar
    Haven't tried this effect myself, but I believe you could do this with BluffTitler as well (though my preference would be with the versatility of Blender or the efficiency of AE).
  13. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    Aviutl has a good easy to use snow (and others) particle emitter. Here is a simple example.
