I have read threads on how to change the region on DVD player but chapter keys on my remote don't work on screen! Any ideas? thanks
Philips may have updated the firmware since those directions came out, breaking the hack. You might make note of the current firmware version and see if it's possible to find older firmware somewhere (Philips may not have older firmware) and see if you can install it. Some players don't allow you to downgrade firmware. Any firmware downgrades you do with the understanding that attempting to downgrade firmware may brick the player and possibly void your warranty.
I'd guess based on my experience with Philips that your player probably is a converting player that can convert PAL DVD video to NTSC output, so if all else fails you could rip the DVDs and reburn them. Ripping will remove the region coding. -
Thanks for info. Will look into it - or otherwise buy a new DVD player!
Does Philips BDP3406/F7 play PAL DVDs on NTSC TV?
By whachano in forum DVD & Blu-ray PlayersReplies: 22Last Post: 3rd Aug 2013, 00:37 -
Playing DVD (VOBS) on Philips DVP5990
By Wanderlustus in forum DVD & Blu-ray PlayersReplies: 7Last Post: 20th Jan 2011, 21:45 -
Making a dvd with an english track from a mkv file that has both japanese and english
By andyjc in forum MacReplies: 0Last Post: 12th Feb 2010, 10:41 -
Philips DVP5992 & PAL DVDs
By kinemax in forum DVD & Blu-ray PlayersReplies: 5Last Post: 21st Feb 2009, 12:03 -
Philips dvdr3590H, hardware clicks and almost ruins cd/dvds.
By aleks93 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 21st Oct 2008, 01:16
