How's everyone doing?
Suppose you do all your MPEG-2 cleanup and send it to HcEnc for re-encoding.
Let's assume that the original file size was 5,000-7000kbps VBR.
Now, suppose you push it up to super high bitrates (say 10,000kbps-15,000kbps 2-pass).
All other settings would be pushed to the best possible options available.
Would quality loss necessarily incur, or is it at least safe to say that, considering the alloted bitrates, quality loss did not necessarily take place?
Results 1 to 14 of 14
As manono points out but might not get the attention it deserves, you MAY NOT NOTICE IT, but yes, quality loss will occur. I'd bet that at bit rates like you propose, you won't notice it.
Do note that some of our experienced members are super critical when it comes to quality, so rather than just have them post and tell you that with their overblown warnings that your re-encoding will completely destroy the quality and it will be unwatchable, yada yada yada, why don't you just try what you propose and see if it meets YOUR needs rather than asking a bunch of (potentially) over critical strangers here about it. -
What I'm curious about is all this "MPEG2 cleanup" that seems to be necessary for some people. By and large, with VERY FEW exceptions, my Hollywood titles seem to have been very well encoded in the first place, so why mess up a good thing, eh? "If it ain't broken..."
Scott -
Yes, of course. Any time you compress with a lossy codec you get losses. The question is how much loss you get. With 10 to 15 Mb/s your losses (relative to the cleaned video) will usually be minimal. If the cleaning you did was significant the final video may look better than the one you started with.
Even at high bitrates, if you A/B compare still frames of original-vs-encoded, the visible differences can be large for some content. You just can't spot those differences in motion though. It's only relevant if you ever intend to process the video again from that re-encode, or grab stills.
noise-free smooth progressive content is far easier to encode than noisy or detailed and/or interlaced content. The former can be visually transparent at 5Mbps. The latter might not be at 15Mbps. Movies that people have "restored" are usually closer to the former.
Cheers,
David. -
I have done a series of experiments, and have seen that the re-encoded product looks fantastic. So my question is answered and it does make sense: Although it may not necessarily be noticeable, loss does take place. I have also transcoded from MPEG-2 to H.264 (with Handbrake) and the results are even more superb. In fact, it looks like the lossless AVI. My theory is that because H.264 is superior, it sticks closer to the source--hence no visually noticeable loss.
AND THAT'S NOT ALL! I can also tap dance with a hemorrhoid-ridden semi-cranky monkey!!!
Watch:
RRRAa tata-tata -dada-rata ta ta dada!
MPEG-2 sucks so bad that it severely screws up some frames in high actions scenes at 40 Mbps. I would never re-encode with MPEG-2 at any bitrate.
...Whereas others don't seem to have any problem with WELL-ENCODED MPEG2 (such as all the numerous cameras and editing systems that utilize and do fine with it).
MPEG2 is perfectly fine - at the right bitrate, and with the right encoder settings. It's just not AS EFFICIENT as MPEG4-ASP, nor MPEG4-AVC. MPEG1 is the same way, just less efficient still.
I could easily show you samples from all 4 that look identical in quality, but differ only in the bitrate required to achieve that quality. In fact, once I'm done with my move in August, I'd be happy to provide them.
Scott -
Are you sure you have ever used an adequate quantization matrix
for your casual "high-bitrate" MPEG-2 encodes?
According to manono, or rather, according to myself at least
, the default MPEG-1/2 matrix
(the one whose intra-mode's first row reads 8, 16, 19, 22, etc.)
sucks royally:
https://forum.videohelp.com/threads/262456-mpeg2-quality-check?p=1568133&viewfull=1#post1568133
https://forum.videohelp.com/threads/240503-1PASS-CCE-quantizer-matrices?p=1418860&viewf...=1#post1418860
https://forum.videohelp.com/threads/270717-How-to-decide-what-custom-matrix-should-be-u...=1#post1622310
http://forum.doom9.org/showthread.php?p=759872#post759872Last edited by El Heggunte; 17th Jun 2013 at 04:27. Reason: better wording
Hard burning with srt onto avi - I need the position of subtitles higher
By rambler in forum SubtitleReplies: 9Last Post: 25th Nov 2012, 13:05 -
Questions about video re-encoding and downscaling - quality loss? bitrates?
By Veid in forum Video ConversionReplies: 1Last Post: 25th Dec 2011, 00:06 -
Best Encoder when encoding with low bitrates
By MI6 in forum Video ConversionReplies: 6Last Post: 27th Nov 2010, 20:37 -
Higher Bitrate = Higher Quality? - 20MBPS difference for 1080p file
By SgtPepper23 in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2009, 07:57 -
Encoding with higher resolution doesn't preserve quality.
By aznstriker92 in forum Video ConversionReplies: 50Last Post: 2nd Oct 2009, 13:38
