Hey guys,
In the past I've been digitizing digibeta tapes with a Sony J30-SDI tape deck using an SDI cable, with a BlackMagic Decklink SDI card and BM Media Express. Unfortunately, I now need to upgrade my systems in order to be able to capture and separate the different audio streams from the tape to the digital file (i.e. stream 1 = Dialogue, stream 2 = M + E)
What I'm wondering is how I should set up the new system, with regards to what I already have. I'll most likely have to buy a new tower as well as Final Cut Pro X, but what capture cards would work for recording with Final Cut Pro X and the current tape deck that I have? Any insight would be greatly appreciated. Thanks!
Your decklink SDI card should be able to handle up to 8 tracks of SDI audio natively.
So far the only thing that the decklink card has been able to do is save the audio streams into one. I.e. Channels 1, 2, 3, & 4 on the tape will all just go into one audio stream. I'm trying to seperate the audio in the same way it's laid out on the tape, and not sure if it's a hardware or software issue, or both
Right, but what other software would be able to handle it? I've thought of Final Cut Pro 7, but unfortunately only Final Cut Pro X is available, and BlackMagic design doesn't offer support for Final Cut Pro X yet
Edit: Yes it does.
http://www.blackmagicdesign.com/products/decklink/techspecs#4013
Best Format To Capture DigiBeta
By gloriouscitizen in forum Newbie / General discussionsReplies: 4Last Post: 22nd Apr 2013, 08:07 -
Audio channels on digibeta
By encodingmonkey in forum MediaReplies: 1Last Post: 21st Nov 2012, 15:39 -
A Question For A Projectionist. (MC to HCCAM or DigiBeta)
By Sullah in forum Newbie / General discussionsReplies: 17Last Post: 14th Feb 2012, 12:43 -
What are you capturing?
By ryangarfield in forum Capturing and VCRReplies: 10Last Post: 20th Apr 2010, 14:16 -
Digibeta Deck as source input for FFmpegX
By reelrootsryan in forum ffmpegX general discussionReplies: 0Last Post: 18th Nov 2008, 16:48
