Hello there...
First Post to the site (Helluva' Site too!) and have a question in regards to my ADVC-100 that I've had on a shelf for some years...
First, is the ADVC-100 (not 110) 'still' a good option for transferring HI-8 and DV tapes to Digital format? I have about 50 of these tapes (total) and would like to get them into a format that is Good quality and can later be 'authored'. My main focus right now is to get a decent DIGITAL copy from these tapes before something happens to them...
I'm familiar with the hook-ups and such, but not sure of which software I should be using to do the following;
-Codecs that need to be installed previous to recording as I am unsure about 'Codecs' and which ones I should be using in order to get the quality and format required for storage and future Authoring...
-The actual "Program" (Software used) to transfer or 'Capture' the video and which format I would need to record to.
**Obviously I have very limited experience, but I these Videos mean a LOT to me and as such, I have set aside 'limited funds' in order to purchase required software, Hardware, etc.. Of course, I also want to 'learn' how to do it properly and figured this Forum was the best place to start**
ANY HELP is greatly appreciated!!
Cheers,
The ADVC-100 converts digital to analog and vice versa.
First, the DV tapes are easy, firewire into your computer, no ADVC necessary
Using the ADVC box you can convert your HI-8 tapes to DV -- that is the only choice with that hardware, and then firewire from the ADVC to the computer.
The simplest software to use is WinDV, https://www.videohelp.com/tools/WinDV but any NLE can handle it -- Premiere, Vegas, etc.
If you have no DV codecs loaded on your system, Cedocida is a good one
https://www.videohelp.com/tools/Cedocida-DV-Codec.
Be sure the dip switches on your ADVC-100 are properly set for your material. (Default is all "off" which should be fine for Canada)
Canopus ADVC-100 vs. ADVC-110 vs. ADVC-300
By TrackingError in forum Capturing and VCRReplies: 36Last Post: 16th Jul 2021, 11:19 -
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 18:26 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 20:52 -
How should I capture my hi 8 videos with my Canopus ADVC 100 and TRV460
By eichelman in forum Capturing and VCRReplies: 4Last Post: 9th Dec 2009, 13:21 -
New PS3 "Slim" plus $100 price drop
By edDV in forum DVD & Blu-ray PlayersReplies: 10Last Post: 19th Aug 2009, 22:35
