Has anyone scrutinized the results of running analog video signals through a video switch prior to capturing? Does it make a visible difference? Any significant signal loss?
I'm getting ready to set up all of my equipment for a big VHS capture project, and I'd like to get one of these for hooking up multiple VCR's to my video capture PC:
http://www.mcmelectronics.com/product/50-7780&p=?&scode=DD1362&trk_msg=9N45IGNCG4I43C9...ampaign=DD1362
It's currently on sale for $29.99 via an email promo.
Thanks!
I've never noticed any degradation of signal or loss through a simple mechanical switcher. Very long cable runs would probably get you more loss or chance of interference. Try to keep your cables short.
Also I'm assuming your signals are standard levels. Line level video (And audio) aren't that high of frequency to worry much about loss within a decently shielded mechanical switcher.
I've used a inexpensive Radio Shack switcher for VHS captures for years with no visible problems. You could test yourself by checking the difference with the signal feeding through a switcher or connected directly, but I doubt you would be able to find any difference. -
Yeah, if you measured the signal on both sides of the switch with an oscilloscope I'm sure you'd see a difference on the order of 0.1 mV or something, but as long as it doesn't make a difference to the human eye I'm fine with it.
Thanks for the feedback guys
I'm gonna get the one I had linked to. Maybe I'll post again on the results after I get it and use it for a while in case someone sees this and might want to buy the same model.
loss of tv tunner signal
By rokunube in forum Capturing and VCRReplies: 3Last Post: 12th Apr 2013, 16:40 -
Signal loss when I press play.
By imma in forum RestorationReplies: 5Last Post: 28th Aug 2012, 21:13 -
Cable Length vs Signal Loss
By nkordyjaka in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 11th Oct 2010, 10:31 -
Using video presence detector to detect blank video signal from switcher.
By rabbi in forum Newbie / General discussionsReplies: 0Last Post: 6th Jul 2010, 02:30 -
A TBC with low bandwidth=signal degradation?
By Cingular in forum RestorationReplies: 16Last Post: 24th Oct 2009, 15:29
