hi everybody,
i need some help
i would like to create a lived anaglyph video from 2 IPwebcams to a streaming in my locale network (without internet access)
by the way of my webpage, a video stream file or something else
I don't know if it's possible to transform video streams iin anaglyph with php (or an other language)
or if i have to use a separate software (in yes case, which one)
my goal would be to obtain something like that http://timgreenfield.blob.core.windows.net/programmerpayback/LiveS3D.html
(cf http://lives3d.codeplex.com/ )...something more simple would be good as well for me...
on my personal server without have to connect on an external website because Iwould like a use of my website outside the internet
thanks a lot if you have a solution for me
if you want more details or precisions about my problem, ask me
Use Stereoscopic Multiplexer (or an AVISynth script - anaglyph should be fairly easy) and feed that into a standard streaming encoder. Upload. Done.
Need more input about specifics of cam models, platform, format of streams, etc (ALWAYS best to err on the side of too much info rather than too little)...
Scott -
stereoscopic mulpiplexer is a good idea,
i've already tried it but i had a problem when i wanted selected my 2 devices (in configuration wizard)
i selected in left and right devices IP CAMERA [JPEG/MJPEG] but write two different URLS seems to be impossible
i have two differents video stream on 2 differents url http://192.168.43.X:8080/videofeed...
when i write the url for left device, it erase what i've written before on right device and same thing in the other way
i'm pretty sure it is because my devices have exactly the same name "IP CAMERA [JPEG/MJPEG]" (in configuration wizard)
but i don't know if it's possible to change the name of one
my devices are smartphones with the app ipwebcam installed on them
my pc is asus x73S / windows 7 -
I remember Enosoft created a "Camera driver Friendly-name renamer", but IIRC that probably only works with DV cams (though you could try). I'm pretty sure you're going to have to figure out how to rename one for that to work.
But I also remember there being a driver on the web that allowed you to use any old standard pair of webcams SPECIFICALLY for anaglyph. See if you can find that. Do a google search on "anaglyph webcam driver", as it comes up with some interesting hits...
How to convert Half SBS to Anaglyph 3D
By VHser in forum Video ConversionReplies: 4Last Post: 9th Sep 2012, 15:42 -
3d SBS to red/cyan anaglyph
By edy_smf in forum Video ConversionReplies: 16Last Post: 4th Apr 2011, 21:19 -
Create Anaglyph 3D Video
By Tugan in forum Video ConversionReplies: 11Last Post: 10th Jan 2011, 22:28 -
HELP! anaglyph bitmap sequence to MPEG2
By AntonioB in forum Video ConversionReplies: 0Last Post: 14th Jul 2010, 12:25 -
Video to 3D Anaglyph
By cd090580 in forum EditingReplies: 3Last Post: 12th Jul 2010, 20:27
