Hi all,
I am a newbie that is fairly familiar with avidemux and avi.net but wants to move on to learning to do video encoding by myself by using the suggested applications mentioned below but I need a little more hand holding help.
This is one of the guides I’m using to set up lame, xvid and Virtualdub.
http://granjow.net/virtualdub-tutorial-installing.html
DgIndex, Avisynth and Virtualdub route was suggested by Jagabo. “If you want learn how to do it all yourself, I recommend using DgIndex, AviSynth, and VirtualDub. Index your VOB sources (and demux the AC3 audio) with DgIndex. Open the video with Mpeg2Source() in AviSynth. Inverse telecine or deinterlace as necessary. Open the AviSynth script in VirtualDub. Import the AC3 audio. Configure Divx/Xvid settings. Save as AVI.“
https://www.videohelp.com/tools/Avisynth
https://www.videohelp.com/tools/DGMPGDec
https://www.videohelp.com/tools/Virtualdub
Which xvid codec is recommended?
http://www.free-codecs.com/download/xvid_codec.htm
http://www.xvid.org/Downloads.15.0.html
I would also eventually want to encode to h264 too, so can you also recommend a download link for the best codec.
For the audio I would be using the following aac, lame and ac3.
I do search for user guides but unfortunately most are old and out of date, and do not include all the required steps and a list of all the necessary programs, codecs etc.
I want to be able to do it correctly and was wondering if you guys would be willing to put together a modern updated guide with the correct steps involved. This way a newbie can have all the relevant update information in one place.
Thanks.
Re-encoding to xvid or h264 is something that is done out of necessity. You are merely making a video smaller is size. You ARE lessening the quality in the process. HOW MUCH quality you are willing to lose is up to you. Beauty is in the eye of the beholder....and that is YOU.
There is no "correct" way.
If storage space is not a problem, keep and watch the original file. It will never get any better than that. -
I am full drunk now, not up-to the neck, but up-to the head and still I can think well (???)
I am trying to get answer by solving mathematics as under:
mean while, please surf guide section here or a specific forum.
wait a second, super computer started processing above equation and getting some answer.
oh! holly cow, it's negative,
how about using DiVX?Last edited by enim; 10th Jun 2013 at 01:15.
Batch xvid avi's to h264 mp4, keep resolution & file size
By marioval in forum Video ConversionReplies: 4Last Post: 10th Sep 2012, 18:13 -
Two-pass XviD encoding in VirtualDub
By wallywalters in forum Newbie / General discussionsReplies: 4Last Post: 18th Jun 2012, 00:11 -
Cooling Solutions - *Solved & updated* Problems w/overheating & idle temps
By Noahtuck in forum ComputerReplies: 21Last Post: 28th Jul 2010, 21:30 -
How to get Xvid encoding in VirtualDub
By Dr_Asik in forum Newbie / General discussionsReplies: 9Last Post: 25th Feb 2010, 10:31 -
h264 and xvid encoding for: near-lossless and high quality ?
By vhelp in forum Video ConversionReplies: 10Last Post: 14th Sep 2008, 15:31
