    Jun 2013
    São Paulo
    got vegas movie studio platinum hd & vegas pro 11 installed
    got main concept dv & xvid codecs installed
    ran gspot and the codec needed for the file i want is Xvid ISO mpeg4 (which says is installed)
    im trying to import this avi file into both programs but it says codec missing on 11 & no video on platinum hd
    btw...even with xvid installed i dont get avi-xvid rendering output format
    help
    Oct 2005
    666th portal
    i'd guess it's a bad file. and you can render to xvid if it's installed, it's in video for windows - video format. you'll need to create a custom template.
    Jun 2013
    São Paulo
    CLOSED!!
    got it...installed xvid codec from cnet
    thanks anyway!
