    Jun 2013
    Natal - RN
    hello, I want to convert a video for the TRP format to watch movies on my tv receiver subscription.
    converted to the format using the TRP program "Aimersoft Video Converter Ultimate" most did not work on my receiver
    Aimersoft Video Converter Ultimate encoding:
    Format : MPEG-TS
    File size : 195 MiB
    Duration : 4mn 57s
    Overall bit rate : 5 502 Kbps
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format profile : Baseline@L3.1
    Format settings, CABAC : No
    Format settings, ReFrames : 2 frames
    Format settings, GOP : M=1, N=24
    Codec ID : 27
    Duration : 4mn 57s
    Bit rate mode : Variable
    Bit rate : 5 037 Kbps
    Maximum bit rate : 7 500 Kbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate : 24.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.228
    Stream size : 179 MiB (92%)
    Audio
    Menu ID : 1 (0x1)
    Format : AC-3
    Format/Info : Audio Coding 3
    Format settings, Endianness : Big
    Codec ID : 129
    Duration : 4mn 57s
    Bit rate mode : Constant
    Bit rate : 192 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Compression mode : Lossy
    Stream size : 6.81 MiB (3%)
    and read on the device (digital receiver) format has to be this:
    Format : MPEG-TS
    Format profile : No PAT/PMT
    File size : 2.00 GiB
    Duration : 19mn 38s
    Overall bit rate : 14.6 Mbps
    Video
    Format : AVC
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Duration : 19mn 38s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Frame rate : 29.970 fps
    Color space : YUV
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio
    Format : AAC
    Format profile : HE-AAC / LC
    Muxing mode : LATM
    Duration : 19mn 38s
    Sampling rate : 48.0 KHz / 24.0 KHz
    Delay relative to video : -941ms
    what should I use to convert to this format to read on the digital receiver?
  2. Formerly 'vaporeon800' Brad's Avatar
    Apr 2001
    Vancouver, Canada
    1. We don't know what model your receiver is.
    2. Why do you think you are able to play random files back on it?
  3. Member DB83's Avatar
    Jul 2007
    I suspect that 2 gig size is set by the OS within the receiver. There will be an index file to control the playback of a file which is longer than 19 minutes.
    I hardly think there is ANY software available to replicate that as you still will not be able to write to the index.
    Jun 2013
    Natal - RN
    the model of this receiver is http://expo.nabshow.com/mynabshow2012/public/Booth.aspx?IndexInList=58&FromPage=nz_ALP...uctName1%20ASC
    Well I know he read this format trp because I put the receiver to record a movie on tv to watch later and put the stick on the computer and looked through the program which was encoding the video that this was
  5. .trp is a just different extension for MPEG Transport Stream.
    Jun 2013
    Natal - RN
    to rotate the film (video) at the receiver have to be this format
    have to finish this format: .TRP
    with the video format: MPEG-TS, Format profile: No PAT/PMT
    Video: AVC / High@L4.0
    Audio: AAC / HE-AAC / LC
    sorry for the english I'm using google translator
  7. On your place i would give a chance to obe-vod which should produce correct trp (ts) files - it is a cmd type tool - so it can be difficult for you to start.
    At a start perhaps you can use command line such as:
    obe-vod --profile high --level 4.0 --preset ultrafast --tune fastdecode -I 12 -i 1 --bframes 0 --fake-interlaced --crf 1 --vbv-maxrate 8000 --vbv-bufsize 4000 --overscan "show" --colorprim "bt709" --transfer "bt709" --colormatrix "bt709" --nal-hrd "fakecbr" --pic-struct --bluray-compat --thread-input --sps-id 1 --aud --force-cfr --ts-muxrate 20000000 --ts-cbr --ts-dvb-au -o %1_uf_fd_.ts %1
    this one is quite crude (was used for me to test particular things) but as obe-vod is a fork of the x264, probably plenty of guys from this forum can help you to tune good quality.
    good luck
    obe-vod can be downloaded from:
    https://code.google.com/p/open-broadcast-encoder/
