hey everyone, I finially got my video card installed and its working great. Except I can only capture 320X240 in vdub, or else i get errors, will captureing in the higher res's make my quality alot better , if so, how? I am upgrading my memory soon, and getting a 6 head VCR, in hopes that that will help the qual a little, will it. I am using adobe premier to add cool transitions and such. But it only can save it as AVI, so then i have to re-encode, loosing more pic quality. so after the VHS>AVI>encode to MP1>bring into Premier then edit,save as AVI> back to mp1...I loose ALOT of pic quality in this process, is there any easier way to do it ?
the steps ive been doing are:
Capture to uncompressed AVI
Edit, add filters,etc encode to MP1
Import into Premier, add FX Save to AVI
Re-encode to MP1
I only have 10 gigs free, so it makes it alot harder, cause i cant leave the uncompreded avi on my hd for too long if im capturing more, thats why i usually immidiatly encode it.
Thanks!!!!!!!!!!!!!!!!!!!
like someone in this forum said before, vcd is not that great.after seeing the VHS > VCD comparision i am much more impressed with vhs. maybe i will put off this whole project until dvd burners come down in price
Results 1 to 1 of 1
Capture Analog 8mm Video 8 Tapes to DV - What equip will produce best Qual
By koop in forum Capturing and VCRReplies: 7Last Post: 4th Apr 2012, 23:36 -
Adobe Premier 5 AVI's won't load into Nero Vision 10
By rlarden in forum Video ConversionReplies: 1Last Post: 2nd Jul 2011, 04:43 -
Capturing HD from HDR-HC1E using Adobe Premier Pro CS4
By Beam in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 6th Jul 2010, 14:36 -
Convert H.264 from my Veho Kuzo to DV AVI for editing in premier 1.5
By guzzuk in forum Video ConversionReplies: 1Last Post: 27th Dec 2009, 04:28 -
Premier 1.5 - importing AVI
By jazzjeppe in forum EditingReplies: 4Last Post: 21st Oct 2007, 06:35
