Results 1 to 20 of 20
  1. what is better for the max quality results?
    is no important file size, is important only the best quality of editing
    thanks to all
  2. They're nearly the same. Of course, what settings you use makes the difference.
  3. and what is the best .h264 encoder for you jagabo?
  4. Originally Posted by marcorocchini View Post
    x264.
  5. Originally Posted by jagabo View Post
    x264.
    General
    Complete name : D:\gatteo\C0010.mxf
    Format : MXF
    Commercial name : XDCAM HD422
    Format profile : OP-1a
    Format settings : Closed / Complete
    File size : 78.3 MiB
    Duration : 10s 880ms
    Overall bit rate : 60.3 Mbps
    Encoded date : 2013-05-24 21:40:57.000
    Writing application : SONY Opt 1.22
    Writing library : SONY Opt 1.22
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : 4:2:2@High
    Format settings, BVOP : Yes
    Format settings, Matrix : Custom
    Format settings, GOP : M=3, N=12
    Format_Settings_Wrapping : Frame
    Bit rate : 50.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 fps
    Standard : Component
    Color space : YUV
    Chroma subsampling : 4:2:2
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.965
    Stream size : 64.8 MiB (83%)
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    I have download and install the x264VFW codec
    Please can you tell me what is the best setting to encode in high quality?
  6. Preset: Placebo
    CRF Rate Factor: 0
  7. what do you need it for ?
    x264 CFR 0 is lossless (no quality loss), but not compatible with many editors, poor editing performance (timeline scrubbing slow)
  8. mmm in virtualdub I get error, please can you download the c0020.mxf file in my dropbox and try to encode in virtualdub?
  9. Again, what do you need it for ?
    There are tradeoffs in terms of compatibility, compression(filesize), quality, editing performance (decoding speed), encoding speed
    Best quality is lossless codecs (e.g. ut video codec, lagarith, huffyuv) , but filesize is large, editing performance is usually slow . UT is probably the best overall, because it's lossless, yet still offers fairly good editing performance
    Commonly used editing intemediates are better in editing performance , minimal quality loss e.g. cineform, prores (mac), matrox MPEG I frame , etc....
  10. the h.264/mp4 output is only for the web.
    But at now I'm not able to find a codec for the blade 2.2 nle editor
    I have try the matrox mpeg 2 I frame HD codec but the 1.0.0.28 build block blade.exe
    the 1.0.0.33 build seems work but when import the trascoded file the image was reversed
    Seem work the morgan MJPEG codec
    while for encoding in H.264 I get many error and I don't able to transcode :=(
  11. you probably need to deinterlace , convert it to 4:2:0 for web
    (4:2:2 is supported in some versions of flash, but it's probably better idea to convert to 4:2:0 for compatibility)
    A very good intermediate on windows is cineform, there is a free version available "go pro cineform studio"
  12. Formerly 'vaporeon800' Brad's Avatar
    Apr 2001
    Vancouver, Canada
    Preset: Placebo
    CRF Rate Factor: 0
    Oooo you must be feeling MEAN this morning!
  13. Originally Posted by poisondeathray View Post
    poisondeathray I would like have a question:
    in Virtualdub is possibile to apply a conversion of level from standard to expanded and chroma filering/interpolation
    as the Matrox plugin in attachement?
  14. this is the attachement
    Image Attached Images
  15. Not sure, try it out
    Personally, I dislike matrox codecs because they are treated as RGB in programs (clipping in a YUV source, unless you correct for it beforehand, or use full or expanded range - but then there is a contrast change) . Other codecs like cineform are treated as YUV, and are better suited for YUV sources
    And if you wanted conversion you can have better control over conversions in avisynth
    EDIT: I see, you're asking if there is a native vdub filter that has those options such as matrox configuration - the answer is no. With the exception of a few, most filters in vdub work in RGB (you already incur a standard range Rec 601 conversion to RGB before the filter) . To do this in vdub, you would need avisynth beforehand
  16. Originally Posted by marcorocchini View Post
    MJPEG is not a standard - MPEG-2 is a standard - huge difference - also MPEG-2 can have custom (flat) quantization matrices and can be 10 bit for DCT, also it can have own metadata and fully support interlace (as MJPEG is progressive).
    So for quality (and compatibility) MPEG-2 seem to be much better choice than MJPEG.
  17. Member Cornucopia's Avatar
    Plenty of mjpegs that are interlaced.
  18. Member vhelp's Avatar
    Mar 2001
    New York
    and, matrox has many mpeg2 codec variations and settings. there is a matrox codec suite that can be d/l 'ed, but i forget the exact name of it. i don't think it is in the tools section though. these (below) are what i have in my codec lineup from that matrox codec suite i installed:
    Matrox DVCPRO
    Matrox DVCPRO HD
    Matrox DVCPRO50
    Matrox EZ-MXF AVI (playback only)
    Matrox HDV (playback only)
    Matrox MPEG-2 I-frame
    Matrox MPEG-2 I-frame + Alpha
    Matrox MPEG-2 I-frame HD
    Matrox MPEG-2 I-frame HD + Alpha
    Matrox Offline HD
    Matrox Uncompressed HD
    Matrox Uncompressed HD + Alpha
    Matrox Uncompressed SD
    Matrox Uncompressed SD + Alpha
  19. Originally Posted by Cornucopia View Post
    Coded as progressive - TFF/BFF flag not follow neither stored.
