I'm trying to make sense of the XML structure to make an SVCD. I want one sequence item with multiple entry points. I want to be able to use NEXT and PREV buttons. My question is, do I use selection items to define this or playlist items? What is the difference? Or am I totally misunderstanding how to do this?
Guest
You can use either.
However, with <selection>, you can define <timeout>, so that after the sequence has finished playing, it will go to another menu (main menu), or a "change disc" screen, etc.
With <playlist>, if you start watching from chapter one all the way to the end, it will then go to <next> which would be chapter2. The behaviour looks really retarded after you've seen it once.
I suggest <selection>
Regards.
Michael Tam
w: Morsels of Evidence -
By way of example, the Extended VCD editor of WinOnCD 3.6 doesn't even permit you to create playlists--everything is a selection.
Playlists do have one benefit: you can specify multiple play items in a single playlist. As far as I know, selections don't do that. (Or maybe I made a typo when I tried it.) -
<playlist> has several benefits, though most of them are minor.
1. as tacosalad stated, you can specify multiple play items
2. you can use <autowait> in conjunction with <auto-pause>
3. you can use <playtime>
4. you can set the <wait> time to zero (if you set <wait> to 0 on a finite loop in <selection> you end up with a random jump rather than no waiting to whatever is defined in <timeout> )
Regards.
Michael Tam
Reading AVCHD Playlist files BDMV\Playlist\*.mpl
By StrangeSolutions in forum Newbie / General discussionsReplies: 11Last Post: 11th Jun 2014, 00:23 -
CLI to XML
By eon_designs in forum Video ConversionReplies: 1Last Post: 29th Apr 2010, 11:50 -
srt to xml ? any tools ?
By sat-jokar in forum SubtitleReplies: 3Last Post: 10th Mar 2009, 09:12 -
DriveImage XML
By blockie@sbcglobal.ne in forum ComputerReplies: 2Last Post: 25th Jul 2008, 17:25 -
ProjectPrefs2.xml keeps old clips
By geohei in forum Authoring (DVD)Replies: 4Last Post: 11th Jul 2007, 08:34
