So this show called To Love Ru got a BD release. And I buy it expecting something great, or atleast slightly acceptable. But I get a terribly done interlaced upscale. So I decided to encode it to look better. I'm satisfied with the script I've written for it so far, with the overall picture quality. But the one thing I couldn't really properly fix was the interlacing. I've included a sample (probably NSFW) It's an mkv remux(untouched)
I'd be grateful if someone can help me fix this.
Thanks.
That's some very strange video. Different parts of the frame have different comb artifacts. Try something like:
Code:ffVideoSource("TLR interlaced.mkv") AssumeTFF() TFM(pp=0) Vinverse() TDecimate() AAA() BilinearResize(856,480) # bilinear to reduce oversharpening halosLast edited by jagabo; 6th Jun 2013 at 18:23.
Awesome man. It works great. So the only problem was that whenever I added any spatial smoothers to that script^, the interlacing kept creeping back in. Which is when I remembered that most of them work for progressive video only. So what I did was first ran the de-interlacing, and then I applied the other filters with the output video from the first. Here's the finished product. Tell me what you think.
Spatial smoother? The sample looked like digital ink+paint to me.
Err, this is the script that I used. After running that^^ to de-interlace.
What would you recommend?Code:ffVideoSource("\TLR interlaced1.mkv") eDeen(7,7,14,1,2) DeHalo_alpha_mt(darkstr=0.2,brightstr=1.0) AAA() -
Let me expand my question: why do you want to use a spatial smoother?
To improve the overall visual quality of the video... There was some grain and all that oversharpening. I figured it would be right to smoothen it out...?
Burning bluray of anime
By arsh231 in forum DVD & Blu-ray WritersReplies: 8Last Post: 31st Jan 2013, 18:53 -
Anime Video Lineart filter(s)
By Taichi in forum Newbie / General discussionsReplies: 6Last Post: 21st Apr 2012, 13:16 -
Anime FPS/Interlaced question...
By alcOre in forum Newbie / General discussionsReplies: 6Last Post: 4th Apr 2009, 10:05 -
Anime DVD to X264 with Staxrip - is it worth using the 'anime' setting?
By Emanef in forum DVD RippingReplies: 2Last Post: 8th Nov 2008, 16:31 -
Creating dvd video with 20+ episodes of anime
By kurt_tml in forum Authoring (DVD)Replies: 9Last Post: 21st Jul 2008, 19:26
