Hi I'm new to this forum, and not very technical, so bear with me!
I have a Panasonic DMR-Ex78 2009 model set top box and recorder which is a 2009 model. I bought this because it had a scart connection which our old Loewe television had. It does not have a usb port. It does have a HDMI AV out port (?)
My television has finally died, and now my concern is access to stuff on the hard drive.
Questions:
Can I get some sort of connector to my computer to do this?
or
Will I be able to purchase a new tele that I will be able to connect to this hard drive? And if I can, what do I need to know?
All advice welcome.
Most new televisions are HDTV flat screen LCD or Plasma panels.
All of these sold since 2009 have HDMI input connections (it is the current standard for connecting DVD players, BluRay players, laptops, phones, tablets and video game consoles to newer TVs).
Since your Panasonic has an HDMI output, no problem: think of HDMI as simply an updated "HDTV" version of SCART. You would need an HDMI cable: these are not expensive from web dealers, but some of the "name" retail shops mark up the prices exorbitantly. Shop carefully: a good cable should not cost more than $10 (US).
You would connect your Panasonic DMR-EX78 HDMI output to any of the HDMI input sockets on the TV. Usually you'd choose the input labeled "HDMI 1" so you would then just select that input on the TV remote control when you want to view recordings on the DMR-EX78.
Antenna connections would remain as they were.Last edited by orsetto; 5th Jun 2013 at 21:04.
Thank you for your quick reply, and clarifying the hdmi output...off I go tv and cable hunting.
which Panasonic camera model?
By incagraphy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 10th Jun 2013, 11:27 -
Panasonic DMR-EX78 - can't burn to DVD+R
By wigman_99 in forum Authoring (DVD)Replies: 2Last Post: 31st May 2010, 10:44 -
Panasonic DVD Recorder-VCR Combo unit model "DMR-ES35V"
By Syd Jamal in forum DVD & Blu-ray RecordersReplies: 4Last Post: 17th Jan 2010, 15:27 -
best vhs playback? panasonic nv-fs200 hq / panasonic dmr-e75v
By overheat in forum Newbie / General discussionsReplies: 6Last Post: 28th May 2009, 20:57 -
Panasonic DMR-EZ28 Previously Recorded Panasonic DVDs
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Oct 2008, 20:45
