Hey guys,
I make movie mashups and I've decided to change my workflow a bit, was hoping you could provide some feedback.
Currently, I am converting MKV to MP4 with Handbrake using the default preset, then using MPEG Streamclip to extract the clips I need. This typically works, although sometimes I see a lot of choppy playback in MPSClip (and not in other players), and I'm wondering if I need to eliminate Handbrake from the process and rely on MPSClip to convert.
In short, what is the best practice for converting blu ray rips to a format that FCPX will work best with?
Also, the primary target for my work is YouTube, Vimeo, DailyMotion, etc., and they generally have the same requirements for videos:
Video
Codecs (in descending order of preference): H.264 preferred, VC-1 acceptable
Aspect: 1280x720 (720p) or 1920x1080 (1080p)
Bitrate: 2 Mbps minimum, 4 Mbps maximum
Framerate: 25 fps (preferred)
2-pass encoding, progressive (not interlaced, this is very important)
Square pixels
Audio
Codecs (in descending order of preference): AAC, MP3, WMA9, MPEG Layer 2
Bitrate: 256 Kbps AAC or 320 Kbps stereo MP3 (ideal), 128 Kbps stereo AAC or 192 Kbps stereo MP3 (minimum); 44100Hz
Container (file format)
MP4, AVI, MOV
Thanks!
Export Functions under MPEG Streamclip
By kannixpert in forum Video ConversionReplies: 0Last Post: 10th Feb 2011, 11:40 -
Lost XviD export support in MPEG Streamclip after upgrade to Snow Leopard
By AVR2 in forum MacReplies: 3Last Post: 6th May 2010, 16:03 -
Audio not synced on Export from MPEG Streamclip
By Luckyword in forum Video Streaming DownloadingReplies: 0Last Post: 1st Nov 2009, 17:45 -
MPEG Streamclip Settings for Editing
By RowlandBTV in forum MacReplies: 11Last Post: 14th May 2009, 14:29 -
MPEG Streamclip question: which is better? QT DV or Export to DV?
By Direwolf in forum MacReplies: 8Last Post: 29th Jan 2009, 11:38
