There is a thread in another forum (found by googling SP and frame packing) that describes adding the 3dplay driver that when engaged would translate the normal 3dvision double-framerate intended output into a frame-packed output. Then of course you would set SP to output in 3dvision mode.
There OUGHT to be some possibility, because clearly 3DBD players such as Cyberlink PowerDVD and Arcsoft TMTcan do it out of the same type cards through to HDMI 1.4a compatible 3D TVs & projectors (such as your own). So maybe it is just a matter of fooling the driver into working (or hacking it).
Otherwise, though, you may for the present be stuck with 1/2 res.
Results 31 to 32 of 32
Thanks Scott,
Ill search Google again for SP and frame packing, if you know a specific place, please let me know.
Thanks for all the help so far, if anything else come to mind, let me know
Elad
Help with movies on cd's
By deb4tlj in forum Newbie / General discussionsReplies: 10Last Post: 13th Aug 2009, 14:02 -
Colorizing old movies:
By offline in forum PollsReplies: 38Last Post: 30th Jun 2009, 21:23 -
Movies from SD-Cards
By Sandayu in forum DVD & Blu-ray PlayersReplies: 4Last Post: 12th Mar 2009, 14:29 -
Movies I like thread
By stiltman in forum Off topicReplies: 6Last Post: 8th Mar 2009, 13:25 -
Movies
By neha28 in forum Video Streaming DownloadingReplies: 2Last Post: 4th Feb 2009, 03:11
