  1. Old problems puzzled me as usual
    French Carlotta PAL DVD, interlace and blend. I've tried yadifmod(edeint=nnedi2()), the interlaced was gone, but the blended frames remained there. I've made two clips from the original DVD to give a whole view
    http://files.videohelp.com/u/221292/demuxed.rar
  2. After YadifMod(mode=1, order=1, edeint=nnedi2(field=3)) use SRestore() to remove most blending and restore the frame rate to 23.976.
  3. MT("""
    yadifmod(mode=1, order=1, edeint=nnedi2(field=3))
    """,threads=0,overlap=8)
    Import("D:\Program Files\Megui\tools\avisynth_plugin\SRestore.avs")
    SRestore(frate="23.976")
    Like this? But it seems not work yet.
  4. Code:
    SRestore()
    is working pretty well here.
  5. But as for this part, there is still some remained blend. If it can't be decimate by merely one code, I'll just ignore it.
    http://files.videohelp.com/u/221292/c.demuxed.rar
  6. It works pretty well on that clip here. SRestore does occasionally make mistakes. And sometimes it's not possible to remove all blended frames, depending on the blending pattern.
  7. Thank you all the time, I guess I have to readjust the subtitle.
