Results 1 to 14 of 14
  1. I was wondering how can I take a YouTube stream and see it in the QuickTime video player as a video stream?
    (I think it might be impossible since YouTube uses Flash objects.)
    (Problem Solved: Kudos to bat999! Will be using alternative program (VLC).)
  2. Anybody?
  3. Anyway, just to get a heads up, this is the YouTube stream I want to turn into a QuickTime video stream:
    http://www.youtube.com/watch?v=xIU2JCwAEek
    If you did convert it, please give me the video stream file.
    Or we can chat what programs I can use to get the stream file myself.
    Plus, I use a Macintosh. So .exe, .bat, or any other Windows file format is not allowed in this thread.
    Thanks, and please respond!
    UPDATE: This video (http://www.youtube.com/watch?v=xIU2JCwAEek), is not a video with a end! This video is live and broadcasted as a YouTube live broadcast, not a normal video!
    Oct 2005
    666th portal
    afaik quicktime can play the mp4 videos that youtube creates. just don't download the flv version, get the mp4 type.
  5. Member Cornucopia's Avatar
    And, since you're on a Mac, you ought to be able to play more of the standard FLVs with Perian. Won't cover ALL the variations, but should help. BTW, Perian is invaluable for Mac/QT users (though I believe it is no longer maintained).
  6. But this is not a video where you just play and then watch it to the end. This is the kind that is like a live show. FLV is not a live streaming format
  7. This is my idea in a more descriptive manner:
    This YouTube video (http://www.youtube.com/watch?v=xIU2JCwAEek) is a live stream. This is not a video with an end (Unless stopped by owner). I want the video to be watched as a live stream in the QuickTime Video Player by grabbing the stream and saving it as a live stream playlist.
    For example, a .pls file that has a audio live stream of the KJFK Air Control Tower. What about VIDEO live stream?
    Keep trying!
    Jan 2003
    India
    Open YouTube, start your video- select resolution you want
    Step1- right click on video-select pop out
    The video will start playing in its own window
    Step2- right click on video in its own window- select copy video location
    Step 3 Open VLC player- open network location- paste - click ok to close dialog box
    Pl note you are not downloading the video- only playing in vlc instead of your browser
    Not from me. Saw it on the net. As per the op, woks with almost all players, which can play a link.
    I have confirmed that it works with vlc.
  9. Sadly, I can't see any "Copy Video Location". Looks old and might NOT work anymore. I need a more modern approach.
    Plus, how would I download a 24/7 Live Stream's pre-recorded footage? It has Terabytes of info! (Sounds crazy, but it is!)
  10. bla bla bla was an annoying post
    Last edited by Pikachu4170; 4th Sep 2016 at 15:33. Reason: Looking at your old posts are weird
  11. Member bat999's Avatar
    Feb 2008
    ... what programs I can use to get the stream file myself.
    Hi
    With Linux I can view that live stream in VLC .
    (I don't have Quicktime installed on my system).
    Using the program "youtube-dl". Look here ---> http://rg3.github.io/youtube-dl/
    This is the command:-
     youtube-dl http://www.youtube.com/watch?v=xIU2JCwAEek -o - | vlc - --meta-title "GoldenCam"
    Maybe you can do something similar with your Macintosh.
    EDIT
    Also can download using this command:-
    youtube-dl http://www.youtube.com/watch?v=xIU2JCwAEek -o - | vlc - --sout="#std{access=file,mux=mp4,dst='GoldenCam.mov'}" vlc://quit
    60 second sample is attached...
  12. Thanks! Anyways, VLC is good enough. And I got Ubuntu Boot Camped in my mac just in case so if there is any trouble using youtube-dl on my mac.
    So, use VLC to view live and QuickTime to playback footage I recorded.
    Again, you saved me once again!
    (Thread may be closed anytime if needed. But to get further feedback, keep it open.)
  13. Member bat999's Avatar
    Feb 2008
    With Ubuntu...
    Install
    sudo apt-get -y install youtube-dl
    Then update
    sudo youtube-dl --update
    @ubuntu:~$ sudo youtube-dl --update
    youtube-dl is up-to-date (2013.05.23)
  14. Originally Posted by bat999
Name:	Screenshot from 2013-06-06 23:28:22.png
    And Holy smokes it worked!
    Thanks so much!
    Cheers!
