I have a Technika 22-228G TV. It has USB capability and I have some MKV files that I want to play on it. I've used G Spot to find some info out about a file that I know will play on it. Its an AVI listed as having the DX50 video codec and under audio it says MPEG-1 Layer 3. I want to convert the MKV files to AVIs of the same configuration so they will play. Does anyone know how I can do this?
dx50= divx.
Use for example freemake video converter, load the mkv, choose to avi, change preset to tv quality xvid/mp3. (xvid should also work fine). If you have HD video then resize to around 720x480/576pixels or lower.
You can also use video to video converter, divx converter, xmedia recode, xvid4psp...Convert to avi with divx or xvid and with mp3 audio. -
No reason to down-scale, if you can enjoy HD.
Just DX50 tag does not confirm 100% DiVX Player compliance. Plus, Technika 22-228G must be able to handle DiVX compliant video stream as well.
if it fails to play.
If you have HD video then re-size to around 720x480/576pixels or lower.
"Hd-ready" doesn't usually mean that it supports HD file source material. Very few dvd/tv divx players supports it. Probably just that it can output it as 1080/720.
Thanks for the suggestions, using freemake as suggested I was able to get the files to play on the tv. Thanks for the help everyone.
.ts MUX demuxing / converting a specific channel
By themoog in forum Video ConversionReplies: 4Last Post: 7th Feb 2013, 04:11 -
Need a little help converting a specific movie file
By Cornholio77 in forum Video ConversionReplies: 2Last Post: 28th Dec 2011, 15:45 -
Converting video to specific format, so hardware will decode
By numnum in forum Video ConversionReplies: 5Last Post: 11th Sep 2011, 15:23 -
Ripping DVD or Converting VOB files at a specific Bitrate - Help a NOOB.
By Corellian Corvette in forum Video ConversionReplies: 3Last Post: 17th Nov 2010, 20:09 -
Cannot make subtitles work with specific avi
By tr_y2k in forum SubtitleReplies: 4Last Post: 4th Dec 2008, 12:24
