I use Speccy to check all temps on my PC and I noticed last night that the "motherboard" temp was a little high and I wondered....where or what is used to monitor the temp on the board itself. Is it the northbridge or southbridge or is it just a sensor. I posted a pic below showing the 3 places I think it might be. If I can find out which one it is I'll try a fan on it and see if it helps but I'm not sure which one monitors the temps?
this isn't as high as it was. Just wanted to show what I meant using Speccy.
which is where the temps is monitored...a,b or c? Or is it somewhere else?
thanks
you might try a better hardware monitoring software to get more info. cpuid hardware monitor is one of several out there.
RipBot264 Temp Folder
By jotpilot in forum Blu-ray RippingReplies: 12Last Post: 11th Jan 2012, 16:45 -
CPU Temp.
By HotDamn! in forum ComputerReplies: 33Last Post: 8th Mar 2010, 13:21 -
Downloading Motherboard Upgrades to my Motherboard
By orfajackson in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2009, 15:54 -
Speedfan and the various temp's ???
By blinky88 in forum ComputerReplies: 10Last Post: 19th Jun 2009, 12:37 -
Processor Temp Help
By mikayd in forum ComputerReplies: 9Last Post: 29th Dec 2008, 21:01
