Results 1 to 9 of 9
  1. Hello
    I recorded something with Audacity and saved it as aup file.
    Now I opened the file in Audacity and this is what I get:
    I do not know why this is happan..
    When I play it, so it sounds just like it looks in the picture.
    Please help me.
    I do not understand why this should happen.
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Don't save it as an AUD file.
    Don't record in/save as 32bit.
  3. Ok ..
    I wished I knew that before
    What can I do to load it properly?
    It weighs 5GB
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    It weighs 5GB
    What?
  5. You say there's nothing to do with it?
    It lost?
    I just think there might be a settings problem ..
  6. Please help me!!
    The recording is very important to me ..
  7. I solved the problem ..
    You can lock the topic
  8. Please share your solution. This thread will exist forever and someone else may need it.
  9. Originally Posted by smrpix View Post
    OK
    you need to open the file Directly with Audacity.
    to do this:
    1) select the aup file and then Press the right button on the mouse
    2)Select "Open With"
    3) Choose Audacity (if you don't have it in the list then select browse and Navigate to the Audacity exe file)
