I still use my 2005 win xp computer for many purposes, for instance to transfer TV recordings from PVR Box to computer via a Pinnacle Studio 500 PCI card. That is, I did so until the computer broke down due to destruction of all MSI K8N NEO4-F motherboard capacitors. I managed to get hold of a new MSI K8N NEO4-F Platinum motherboard and at the same time exchanged the cpu from AMD Athlon 64 3700 to AMD Athlon 64x2 4200 2.2 GHz. The total running time for the Pinnacle PCI card may be in excess of 200 hours.
Question: Could this heavy use of the PCI card have caused the capacitor breakdown? Mostly I transfer movies with a duration of 90 min. Would it be advisable to take a break halfway, or should I refrain from this procedure totally?
Heavy use or otherwise of the pinnacle card has little to do with the main board capacitor destruction. Electrolytic capacitors die all the time, some sooner than others.
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i". -
Thank you, I think I`ll continue using the Pinnacle card like I used to.
On several older motherboards heat was a real capacitor killer. Even Asus, known for its performance and overclockability, had electrolytic caps go belly up in relatively short times due to heat.
A good motherboard should be designed to run at the maximum heat and handle it OK. Check specs for high-temp or high-rel caps, or do some detective work before you possibly buy a MB with the same problem again.
Where to buy capacitors online?
By freebird73717 in forum ComputerReplies: 4Last Post: 27th Oct 2011, 21:24 -
What do you used for a PCI xpress firewire card?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 5th Sep 2011, 21:45 -
Capacitors for a JVC DR-MH30SEK
By ETON993 in forum Newbie / General discussionsReplies: 6Last Post: 15th Aug 2009, 15:36 -
PCI Graphics Card
By blueyonder in forum ComputerReplies: 20Last Post: 6th Jun 2009, 11:40 -
dvr pci card
By platonas in forum Newbie / General discussionsReplies: 2Last Post: 19th Feb 2009, 04:37
