I want to make a time-lapse video. I don't want motion blur. I want somewhat slower motion for the subjects I'm recording. Here is an example from YouTube of the type of motion I want.
www.youtube.com/watch?v=Nb5GpV_LUuU&HD=1
As you can see, the people at the Coachilla festival are walking fast in this time-lapse video, but not tooo fast. They are walking at a good pace. Could someone help me figure out the interval, playback rate, etc. Of this video? I'd appreciate it!
Thanks!
About 5 frames per sec., more or less. It's either undercranked, or they had an intervalometer function in their camera.
What you want to do is called frame rate decimation. It reduces the number of frames by the specified factor, outputing the remainder at the original frame rate. This perceptually speeds up motion. For what you want here a factor from 2 to 5 will probably work.
Various tools have their own ways of doing this. In VirtualDub:
- decide on a decimation factor
- navigate to Video > Frame Rate
- In 'No change (current: mm.nnn fps)' note the current frame rate mm.nnn
- click 'Change frame rate to (fps)' and enter a value = current x factor, e.g. 25 x 5 = 125
- click 'Decimate by' and enter your factor, e.g. 5
- (To leave video and audio quality unchanged) select Video > Direct stream copy and Audio > Direct stream copy
- Save the result with File > Save as AVI
The same approach works with other tools, too, although the commands will differ of course.
Cheers,
Francois
Time Lapse Video from existing WMV file
By willboss in forum Newbie / General discussionsReplies: 5Last Post: 17th Sep 2013, 03:35 -
Best method for time lapse video
By jairovital in forum EditingReplies: 38Last Post: 26th Apr 2012, 13:11 -
Time-Lapse Video Does Not Play Smoothly
By radardetector in forum Newbie / General discussionsReplies: 16Last Post: 17th May 2011, 11:21 -
Trying to make a time-lapse video (speeding up original footage): How?
By maskingtape in forum EditingReplies: 30Last Post: 16th Jul 2010, 00:39 -
High Res Time Lapse images to AVCHD video (play on Viera TV via SDHC)
By Deefa in forum Video ConversionReplies: 5Last Post: 16th Jun 2010, 05:21
