I recorded a video from the livestream. I wanna share it with my friends who didn't watch it and now I have a problem. It's the second time when I captured stream with rtmpdump helper and this problem still happens. Video plays properly only in some software like PotPlayer or VLC, but when I try to edit it (cut out the adverts or change the resolution) the output file loses audio ( I got only video without sound), or the audio and video are out of sync with each other or video is without sound and looks like in slow motion. I'm using Vdub or Handbrake and tested many progs for converting files. Is it any possibility to get the correct video file? Avidemux doesn't work for me ;/
Are we supposed to guess at what video and audio codecs are used in this video file that you cannot edit and only plays in a few players?
Oh I'm sorry, here is what I got from PotPLayer :
General
File size : 1.54 GiB
Duration : 1h 32mn
Overall bit rate : 2 368 Kbps
_videokeyframe_frequency : 3.003
_audiodevice : Elemental Technologies Live
_videodevice : Elemental Technologies Live
Video
Format : AVC
Format profile : Main@L3.0
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Codec ID : 7
Duration : 1h 32mn
Bit rate mode : Constant
Bit rate : 608 Kbps
Width : 576 pixels
Height : 324 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.109
Stream size : 404 MiB (26%)
Audio
Format : AAC
Format profile : LC
Codec ID : 10
Duration : 1h 32mn
Bit rate : 160 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Compression mode : Lossy
Delay relative to video : 11ms
Stream size : 106 MiB (7%)
After Encoding Handbrake gives Error and Output video doesn't work
By ConverterCrazy in forum Newbie / General discussionsReplies: 3Last Post: 12th Sep 2011, 08:36 -
Sound doesn't convert using AutoGK
By Looler in forum Video ConversionReplies: 6Last Post: 25th Sep 2010, 21:40 -
mpg with sound that doesn't play
By sivodsi in forum Newbie / General discussionsReplies: 3Last Post: 13th Jan 2010, 08:38 -
Encoding with higher resolution doesn't preserve quality.
By aznstriker92 in forum Video ConversionReplies: 50Last Post: 2nd Oct 2009, 13:38 -
Why doesn't sound work when playing through local network?
By Obamargarine in forum Software PlayingReplies: 1Last Post: 23rd Feb 2009, 13:39
